Driver Side Fresh Air Vent Baffle - 66 442
Old Sep 3, 2012 | 12:21 PM
RandyS's Avatar
I am in need of a fresh air baffle (I think that's what it is called) for the drivers side on my 66 442. This is the port that is behind the kick panel that let's fresh air in to the car. The original one broke and the oval door won't pivot at all.
Thanks,
Randy
Old Sep 5, 2012 | 10:21 AM
RandyS's Avatar
Anyone have one of these?
Old Sep 5, 2012 | 10:35 AM
Oldsmaniac's Avatar
Do you mean the floor vent assembly with pull ****/cable?
Old Sep 5, 2012 | 12:26 PM
RandyS's Avatar
Aaaahhhhhh yes, that's it!
Old Sep 5, 2012 | 12:29 PM
TK-65's Avatar
I might have one from a 65 I parted out. I know I kept it but I cleaned out the shed a month ago. Ill have to check to see if I still have it and if its the side you need.
Old Sep 5, 2012 | 01:19 PM
Oldsmaniac's Avatar
I can check too, I parted a couple of 67's..
Old Sep 7, 2012 | 05:37 PM
TK-65's Avatar
I still have it, no cable anymore and not sure what side it is. Looks like it may work for either side. Let me know if you want it.
Old Sep 8, 2012 | 07:43 AM
RandyS's Avatar
I took a couple of pics of the outside of the baffle. It appears that there is a difference between the Dr & Pass sides. There is a lip that goes over the top which I assume holds some insulation in place, and one side is deeper than the other. The deeper side is toward the front of the car. If you have one like this, I will take it.
Thanks,
Randy
Old Sep 16, 2012 | 07:49 AM
RandyS's Avatar
I am still in need of this part if anyone has one.
Old Sep 16, 2012 | 12:26 PM
65B01Delta's Avatar
I have a 67 442.. I'll check & see If it's still there.
Old Sep 29, 2012 | 10:27 AM
RandyS's Avatar
Still looking for one of these if anyone has one.
Old Sep 29, 2012 | 01:08 PM
65B01Delta's Avatar
Air Box Vent
I'll check my 67 442 today that I'm parting & get back with you.
Old Sep 29, 2012 | 02:11 PM
65B01Delta's Avatar
Here's one out of a 67 442 that I just pulled 10 minutes ago.. The cable needed a little oil, now it works just fine.
I see by looking at your pictures, the 66 year is different. My Bad.
Old Sep 30, 2012 | 03:52 PM
Oldsmaniac's Avatar
I have one from a cheaper interior....no carpet... email me direct if you are interested. j.blusnavage@att.net
Old Oct 1, 2012 | 05:26 PM
RandyS's Avatar
Looks like the baffle is different between '66 and '67. I guess I will need one out of a '66. Found out they are interchangeable from side to side, so if anyone has one it should work.
84oldsDelta88
20
Jan 12, 2016 01:36 PM
elkow30
May 13, 2014 10:35 AM
RickH
Jun 15, 2012 07:08 AM
Pacecar
Mar 24, 2012 07:27 AM
Dec 10, 2011 07:49 AM
