Down on my shift
Down on my shift
Looking for a Throttle Switch Assembly. It si located in the engine compartment at the fire wall mounted on the accellerator linkage, used in a 1965 Dynamic 88 425 HC w/ a 400 auto trans, car will not down shift into pass gear. Please help!
But you should really check your switch to see if it is indeed bad. Use an ohm meter. If you need instructions email me and we will exchange telephone numbers so I can explain it to you, I am not fond of typing a long post explaining it all.
Mike
Alocatelli
December 10th, 2012 07:49 AM
455for30y
June 27th, 2007 12:58 AM
