Down on my shift
Old May 10, 2011 | 05:02 PM
HIGHCOMP425's Avatar
Down on my shift
Looking for a Throttle Switch Assembly. It si located in the engine compartment at the fire wall mounted on the accellerator linkage, used in a 1965 Dynamic 88 425 HC w/ a 400 auto trans, car will not down shift into pass gear. Please help!
Old May 10, 2011 | 05:22 PM
66luvr's Avatar
I have the switch assembly from a 65 Delta which had a 425 with a 2bbl carb and a 400 turbo with switch pitch. I parted the car because it was hit hard in the rear. If you are interested you can send me an email and I will hunt it up and send a pic to your email. My email is dadphelps@yahoo.com .
But you should really check your switch to see if it is indeed bad. Use an ohm meter. If you need instructions email me and we will exchange telephone numbers so I can explain it to you, I am not fond of typing a long post explaining it all.
Mike
Robert Kiedrowski
Nov 5, 2023 11:23 AM
Alocatelli
Dec 10, 2012 07:49 AM
66ninetyeightls
Sep 20, 2011 06:47 PM
327OldsCutlass
Feb 9, 2011 01:56 PM
