Dip Stick
Old Mar 25, 2015 | 05:33 AM
Skeetman's Avatar
Dip Stick
I am looking for a source to buy an oil dip stick for my 67 Cutlass 330 motor. The chrome aftermarket dip stick that came with the car is crap and has a very tight fit. Used would be OK. What other engines would use the same dip stick?
Old Mar 25, 2015 | 07:28 AM
RetroRanger's Avatar
72 Olds CS
I used the chrome aftermarket DS, another member advised me to file the flare slightly to allow it to fit in the block, measure the old and new flare w calipers to get a similar size.
also the chrome DS is not stamped the same as the original as far as full and add. see pic below the flares are lined up the stampings show the different level
Old Mar 25, 2015 | 07:53 AM
After any dipstick change I always check the oil level after a fresh oil change. If it's off I use a file and put a notch at the correct level.
Old Mar 25, 2015 | 08:41 AM
lemoldsnut's Avatar
I have a few core 330 engines that I could probably come up with a dip stick from do you need the stick and tube?
Email me direct
lemoldsnut@aol.com
Larry
Redmond, OR
calls west coast time 8 am to 8 pm 541-815-4363
bulldog
Jun 8, 2010 06:37 PM
fmay50
Dec 17, 2009 10:45 PM
hamm36
Jul 15, 2008 10:23 AM
Olds luvr
Apr 22, 2008 05:20 PM
leslie
Ninety-Eight
Sep 17, 2007 06:17 PM
