Choke Thermostat for a 1966 cutlass 4bbl
Old May 28, 2013 | 03:31 PM
66olds4dr's Avatar
Hi,
Does anyone have Choke Thermostat new or used (good condition) for a 1966 cutlass 4bbl?
Delco p/n:7036095
RP 29984 B-1
Thanks,
Jon
Old May 28, 2013 | 04:11 PM
You should be able to get a replacement choke from the parts store. I don't think there is any difference between an OE unit and an aftermarket unit. It is just a phenolic cover for the heat stove with a gasket and a bimetallic spring on the back side.
Old May 29, 2013 | 07:55 AM
ROCKETMAN269V's Avatar
I believe that '66 is in the manifold; a coiled spring with a rod that goes up to the choke and a tin cover.
Old May 29, 2013 | 09:02 AM
TripDeuces's Avatar
I have one, just have to find it. It's aftermarket and looks like the original but made from aluminum. PM me and I'll look around for it. Can't remember where I got it or I'd steer you in the right direction. Maybe Ames Performance?
Wait I'm smoking crack.......I got it for my Tri-Carb. Not sure that is the same as the 4bbl version
Old May 29, 2013 | 09:05 AM
Olds24's Avatar
I have an original on a 66 330 here in shop, Let me know if you still need.
Old May 29, 2013 | 02:42 PM
11971four4two's Avatar
MOTORHEAD
If you want an oem one send me a pm
Old May 31, 2013 | 05:47 PM
66olds4dr's Avatar
Thank you for your help. I was able to source one.
240 Gordy
Oct 11, 2020 10:04 AM
442mark
Sep 22, 2013 05:50 PM
1k442
Nov 27, 2012 11:18 AM
rroth01
Jun 28, 2011 08:45 PM
cutlass47
Apr 17, 2009 07:02 AM
