A C Duct Connector
A C Duct Connector
Thought I had everthing..now I discovered I'm missing this connector #404802 in the AM P-69. On the drivers side it is not showing a connector-is there something? I like the part, "as required".![Confused](https://classicoldsmobile.com/forums/images/smilies/confused.gif)
Anyone got this piece?
Thanks,
AL
Thanks,
AL
Al, check with Eric (jensenracing77) or Scott (Oldspackrat). They are both fairly close to you in Indiana. Brian Trick (507OLDS) is also close in Erie PA and also may have them.
Eric: https://classicoldsmobile.com/forums...member&u=14140
Scott: https://classicoldsmobile.com/forums...=newpm&u=29498
Brian: https://classicoldsmobile.com/forums...=newpm&u=25006
and that part just "pops" into place. you have the part that is screws onto the dash pad, it has two tabs poking out that fits into the two square holes on the part that 69442murph posted. do you need just the connector or the entire hose with it? i have both but the ones with the hose still attached are hard to ship without damage to the hose.
Al, we may have a problem. i sent just the passenger side. for some reason i was thinking that was all you were looking for. if you need the driver side, it is a little differant than the passenger side. the passenger side has the part that screws to the dash pad and the connector pop onto it. for the driver side there is no connector. it only has the part that screws onto the dash pad and the duct staples to it. did you need the part that screws to the dash for the driver side? let me know and i will dig one up for you.
Bernhard
April 27th, 2013 10:54 PM
