A C Duct Connector
Old Jun 9, 2012 | 07:17 PM
Al Graaf's Avatar
Formerly "Shimmer"
A C Duct Connector
Thought I had everthing..now I discovered I'm missing this connector #404802 in the AM P-69. On the drivers side it is not showing a connector-is there something? I like the part, "as required".
Anyone got this piece?
Thanks,
AL
Old Jun 9, 2012 | 08:35 PM
Al, check with Eric (jensenracing77) or Scott (Oldspackrat). They are both fairly close to you in Indiana. Brian Trick (507OLDS) is also close in Erie PA and also may have them.
Eric: https://classicoldsmobile.com/forums...member&u=14140
Scott: https://classicoldsmobile.com/forums...=newpm&u=29498
Brian: https://classicoldsmobile.com/forums...=newpm&u=25006
Old Jun 17, 2012 | 07:58 PM
69442murph's Avatar
I could not find a part number on this piece, but believe this is what you are after?
thanks
Old Jun 18, 2012 | 02:19 AM
jensenracing77's Avatar
and that part just "pops" into place. you have the part that is screws onto the dash pad, it has two tabs poking out that fits into the two square holes on the part that 69442murph posted. do you need just the connector or the entire hose with it? i have both but the ones with the hose still attached are hard to ship without damage to the hose.
Old Jun 18, 2012 | 04:23 AM
Al Graaf's Avatar
Formerly "Shimmer"
thanks
That's it!!
Old Jun 19, 2012 | 02:38 PM
Al Graaf's Avatar
Formerly "Shimmer"
thanks
Eric had them. Thank you for the picture and help!
AL
Old Jun 19, 2012 | 03:33 PM
Al, we may have a problem. i sent just the passenger side. for some reason i was thinking that was all you were looking for. if you need the driver side, it is a little differant than the passenger side. the passenger side has the part that screws to the dash pad and the connector pop onto it. for the driver side there is no connector. it only has the part that screws onto the dash pad and the duct staples to it. did you need the part that screws to the dash for the driver side? let me know and i will dig one up for you.
Bernhard
Apr 27, 2013 10:54 PM
gglow
Jan 19, 2010 03:31 PM
Flye
Jun 25, 2009 01:46 PM
tarheeldoc
Jun 3, 2009 06:42 AM
woodie582
Nov 7, 2008 01:07 PM
