A body frame
A body frame
Looking for an A body frame, 112", with suspension for a street rod project near N Florida.
Edit: Sorry got some bad info, a A body is not a 112" wheelbase. At least my 67 Cutlass isn't. Back to research.
Maybe 68-72?
Maybe 68-72?
A body frame
I have a couple down here in South FL. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
look here...its what i used to do a street rod..i got it within an inch..and worked fine...i use it all the time for rear end widths too
http://www.crankshaftcoalition.com/w...l_measurements
you can separate the frame at the factory joints to loose length too..i used to do it all the time..be a good welder or find one...its your life...and it isnt really that hard..
the broker you is..the more you will did...
perimeter frames are basically 4 pieces..a front stub..a rear stubb and 2 rails that hold the stubs together..neither stub really cares how long the rails are, as long as it all square...i know thats over simplified...but thats the truth as i know it
1969goatman
Aug 30, 2010 07:44 PM
