A body frame
Old Apr 13, 2018 | 07:24 AM
Roger60's Avatar
A body frame
Looking for an A body frame, 112", with suspension for a street rod project near N Florida.
Edit: Sorry got some bad info, a A body is not a 112" wheelbase. At least my 67 Cutlass isn't. Back to research.
Maybe 68-72?
Old Apr 13, 2018 | 07:30 AM
ROCKETMAN269V's Avatar
A body frame
I have a couple down here in South FL. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old Apr 13, 2018 | 12:50 PM
TripDeuces's Avatar
Yes 68-72 is 112"
Old Apr 13, 2018 | 02:17 PM
geowindow6768's Avatar
'73 - '77 is also 112"
I sold one with a complete drivetrain 2 months ago
Old Apr 13, 2018 | 02:23 PM
May be, but won't interchange with the '68-'72.
Old Apr 13, 2018 | 02:28 PM
Ancient Iron's Avatar
'64 thru '67 was 115" wheelbase
Old Apr 14, 2018 | 02:29 PM
Roger60's Avatar
Turns out after closer examination and some research, I need a 110" wb. Not sure if they exist.
Old Apr 14, 2018 | 03:11 PM
marxjunk's Avatar
look here...its what i used to do a street rod..i got it within an inch..and worked fine...i use it all the time for rear end widths too
http://www.crankshaftcoalition.com/w...l_measurements
Old Apr 14, 2018 | 03:14 PM
marxjunk's Avatar
you can separate the frame at the factory joints to loose length too..i used to do it all the time..be a good welder or find one...its your life...and it isnt really that hard..
the broker you is..the more you will did...
perimeter frames are basically 4 pieces..a front stub..a rear stubb and 2 rails that hold the stubs together..neither stub really cares how long the rails are, as long as it all square...i know thats over simplified...but thats the truth as i know it
Old Apr 19, 2018 | 05:40 AM
Sooo, have you found a frame yet?
Old Apr 19, 2018 | 05:44 AM
Email sent.
alburk
Oct 2, 2016 04:35 PM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
