78 Cutlass Supreme upper rear window molding
Looking for the upper rear window molding for a 78 Cutlass Supreme coupe.
Has to be from a full vinyl top car, not the landau top as they are different.
Hopefully you can see it in the pic if you zoom in on it, has a nice dent just off center.
Let me know if you can help, Thanks.
Need upper mldg
Need upper mldg
In looking at this piece, they look the same as the non-vinyl roof cars (?). The full vinyl roof was not padded and was very thin, it may be likely a replacement from a non-vinyl roof 1978-1979-1980 Cutlass may help out.
I did find this parts car on DVAP that appears to have the part the OP is looking for
1978 Cutlass - DVAP
I have a ton of 1978-80 Oldsmobile Cutlass parts but couldn't find the rear window trim I knew I stashed away years ago. I came across 2 sets of both front and rear windshield trim for the 1978-80 Salons but not the one I had for the Supreme/Calais models. I'll try looking for it again. If I find it, I'll pm you. If you need any other parts for your 1978 just let me know. I may have it. I've owned my 1979 Hurst/Olds for over 22 years now and every time I saw a part I might have needed for it in a local salvage yard, I picked it up. I see you're in NH. I live in Leominster, MA which is only about 20 minutes from the border at Brookline, NH.
Phil
Phil
WOW! Man, that is one scorched 78 Cutlass. I can see there was a vinyl roof on this one at one time, the dead giveaway is the fact it was not painted were the top was, a GM trademark if there ever was one. And, from what I can see the stainless steel trim around the back window is the same as if the car did not have a vinyl roof. Thanks for the thread Allan, that was a good template.
I have this trim off a 78 cutlass supreme , if you still need . e-mail me at d.rocwal@gmail.com .
rocwal
Dan B
rocwal
Dan B
