71 455 flexplate
Old January 25th, 2015, 03:36 PM
billwaldo's Avatar
71 455 flexplate
69 will not work,bolt holes don't line up.has to be 71 or later.
thanks
waldo
billwaldo is offline
Old January 26th, 2015, 04:08 AM
ROCKETMAN269V's Avatar
71 455 flexplate
All the same, small block & big block, '68 and up. Perhaps you have a 425 or early ('65-'67) 400. I have both. Thanks, Bob.
ROCKETMAN269V is offline
Old January 26th, 2015, 06:51 AM
thanks
waldo
What Bob said. Do you possibly have a 1965-67 forged crank in your 455? If not, any 1968-1990 engine (except for FWD 307 applications) uses the same flexplate and all interchange.
joe_padavano is offline
Old January 26th, 2015, 07:07 AM
halfmoontrail's Avatar
Forgive me if you tried this, but they only bolt up in one place, rotate until bolt holes line up.
Steve
halfmoontrail is offline
Old January 26th, 2015, 07:16 AM
Steve
Along the same line, we assume you have the correct side outward.
Old January 26th, 2015, 09:43 AM
Steve
Good point Steve!
Old January 26th, 2015, 10:00 AM
Octania's Avatar
And, if you try to put a 68+ onto a pre-68 crank, two holes will not line up, unless you flip it over, then you can get 5 of the in..... an engine I bought once.
Make sure what crank you have then go shopping. Shape of the notch in the OD of the mtg flange? Pic?
Octania is offline
csouth
December 7th, 2012 04:53 AM
real57vetteguy
August 8th, 2012 07:54 AM
olds455
May 17th, 2010 04:43 PM
ctrain22
July 10th, 2009 08:13 AM
1FSTLS1
May 10th, 2008 09:40 AM
Quick Reply: 71 455 flexplate
