71 455 flexplate
Old Jan 25, 2015 | 03:36 PM
billwaldo's Avatar
71 455 flexplate
69 will not work,bolt holes don't line up.has to be 71 or later.
thanks
waldo
Old Jan 26, 2015 | 04:08 AM
ROCKETMAN269V's Avatar
71 455 flexplate
All the same, small block & big block, '68 and up. Perhaps you have a 425 or early ('65-'67) 400. I have both. Thanks, Bob.
Old Jan 26, 2015 | 06:51 AM
thanks
waldo
What Bob said. Do you possibly have a 1965-67 forged crank in your 455? If not, any 1968-1990 engine (except for FWD 307 applications) uses the same flexplate and all interchange.
Old Jan 26, 2015 | 07:07 AM
halfmoontrail's Avatar
Forgive me if you tried this, but they only bolt up in one place, rotate until bolt holes line up.
Steve
Old Jan 26, 2015 | 07:16 AM
Steve
Along the same line, we assume you have the correct side outward.
Old Jan 26, 2015 | 09:43 AM
Steve
Good point Steve!
Old Jan 26, 2015 | 10:00 AM
Octania's Avatar
And, if you try to put a 68+ onto a pre-68 crank, two holes will not line up, unless you flip it over, then you can get 5 of the in..... an engine I bought once.
Make sure what crank you have then go shopping. Shape of the notch in the OD of the mtg flange? Pic?
csouth
Dec 7, 2012 04:53 AM
real57vetteguy
Aug 8, 2012 07:54 AM
olds455
May 17, 2010 04:43 PM
ctrain22
Jul 10, 2009 08:13 AM
1FSTLS1
May 10, 2008 09:40 AM
