'67 Toronado / 88 / 98 tilt/telescopic steering wheel
****EDIT**** Got what I needed - thank you!!!
My '67 three spoke wheel is pretty bad. I'm looking to replace it with either a standard or deluxe style tilt/tele wheel from either '66 or '67. It's different than the regular wheels without the telescopic function, so regular wheels won't work. Let me know what you have! It doesn't have to be perfect - mine is pretty cracked up. "Reparable and usable as-is" would be a good one for me to consider. Thanks!
Current wheel - front looks decent, back is in pieces...
Just a heads up, the 1968 tilt tele wheel looks the same as your pictures. The 1966 Toronado had a different steering wheel and to release the telescopic action one would twist the center steering wheel emblem.
Here is my 68 wheel for comparison:
Thank you for sharing Tom. I've got a couple 1968 tilt tele columns but hadn't realized they were rim blow wheels. So they wouldn't be an easy swap. It would have to be a 1967 wheel to be an easy swap.
John
John
I think the wheel itself will fit. It just will not look quite the same as a 67 wheel. There is also a good chance the rim-blow switch has gotten hard over the years. Unlike Mopar and Ford units, the GM switch is not designed to be removed. I had to epoxy a 69 Mustang switch into my wheel and then body-work to it as it was about 1/8" narrower than the original oldsmobile switch.
Zoom in on Mike's and Loaded's pics and you'll see a small **** sticking up just above the steering wheel hub. Move it to left to unlock the wheel and adjust it in or out. Move back to the right to lock it in desired position.
I appreciate all the information here. In ‘67 they had a wheel very similar to the ‘66, only the spokes were black instead of chrome. I know the column is the same for 66-67, so I imagine a ‘66 wheel would fit if I had the whole collar assembly with the center locking mechanism. I wish I had taken one apart so I knew more about it.
cfair
June 27th, 2021 12:16 AM
aliensatemybuick
May 15th, 2010 08:21 AM
