67 Cutlass high fan resistor
Old Apr 3, 2018 | 11:53 AM
Roger60's Avatar
Can't find the correct resistor to operate the high a/c fan. First photo is the one I need, second is the only one I can find and it does not work even if you redo the wires to fit. Any ideas?
Old Apr 3, 2018 | 01:46 PM
jcdynamic88's Avatar
i was under the impression the high speed doesn't go through the resistor,that it is a separate wire.
Old Apr 3, 2018 | 03:08 PM
lunaboy's Avatar
The Rocket Astronomer
pm me. Direct email and I am sure I have one from a 66 if they are the same
Old Apr 3, 2018 | 03:25 PM
Roger60's Avatar
I'm not sure. But I'd like to know.
Old Apr 3, 2018 | 03:30 PM
i'm pretty sure high speed is not resisted,it is full voltage,separate circuit
Old Apr 4, 2018 | 04:37 AM
Roger60's Avatar
Found an online diagram, seems high fan goes to a blower relay.
Old Apr 4, 2018 | 04:44 AM
i would check and clean/tighten connections on the relay(once you find it)
Old Apr 4, 2018 | 09:31 AM
mrolds69's Avatar
I know on my 69 442, the high speed runs through an under hood fuse holder built into the wiring. If that fuse blows...no high speed, but the other 3 speeds will work.
Old Apr 4, 2018 | 10:16 AM
Roger60's Avatar
The relay is new, but I will check the connections and look for that fuse. Thanks
Old Apr 4, 2018 | 10:19 AM
mrolds69's Avatar
On my car, it's a black wire with an orange stripe. I think it does go to the relay. It's in the wiring on the driver inner fender. The fuse is small, like 1/2" long.
Old Apr 5, 2018 | 05:42 AM
Roger60's Avatar
Blown Fuse!! You don't know how long I've been fighting this. Thank you.
Old Apr 5, 2018 | 08:20 AM
mrolds69's Avatar
Glad to help! Thanks for letting me know it's fixed, it's always good to get a reply. For my own info...it was that little guy fuse in the wiring like my car? I really don't know 67's too well.
Old Apr 5, 2018 | 08:50 AM
Roger60's Avatar
[QUOTE=mrolds69;1087011]Glad to help! Thanks for letting me know it's fixed, it's always good to get a reply. For my own info...it was that little guy fuse in the wiring like my car? I really don't know 67's too well.[/QUOT
Yes 30a right where you said it would be.
Old Apr 5, 2018 | 01:47 PM
you da man frankie!
Old Apr 5, 2018 | 02:47 PM
mrolds69's Avatar
Thanks Jim! Yeah...even a blind squirrel finds an acorn once in a while. lol
Bee Saint Louis
Apr 13, 2025 08:28 AM
ignachuck
Apr 23, 2016 03:25 PM
oldspackrat
Apr 14, 2016 01:12 PM
ignachuck
Feb 23, 2016 04:36 PM
amercer7155
Jun 13, 2014 12:10 PM
