65 Cutlass core support
I may need to buy a 65 ( not 64 they are NOT the same) core support for my 64 F-85 pro-touring build. I have discovered that the 65's are 3 inches longer-deeper in the cradle where the radiator sits. I live in Dallas would like to find a rust free within driving distance. Without it I may not have enough cooling space for the BB 425.
If you don't find one local I've got one up in Oregon. Somewhere I was told the 6 cylinder and 8 cylinder engine equipped cars had different core supports in 1964 and 65. Does that sound familiar to you? John
Last edited by 2blu442; December 31st, 2011 at 05:15 PM. Reason: Did finish my thought...
4 different part #'s listed for 64
6cyl 3000122
6cyl with Air Cond 3000126
8cyl 3001445
8cyl with Air Cond 3001446
3 different part #'s listed for 65
65 3005245
65 with Air Cond 3005243
65 with 442 option 3005241
Possible radiator mounting issues between them? Henry
6cyl 3000122
8cyl 3001445
65 3005245
I think some of the difference maybe to is that the brackets that bolt to the bottom of the core support to hold the radiator in are different sizes to hold the correct radiator in place. I have to different sizes one you see in place is three inches wide, and I have another pair that is 2.5 inches wide. But with A/C and a trans cooler plus a 500 HP 425 I don't think the 64 core support has enough room-air space. I will start calling tomorrow. I know that a 65 core support with aluminum radiator with a shroud and 2 electric fans will work. If that is the case I will either have to modify the one I have or start over and locate a 65.
No it is a 65 but they list all manner of configurations. You just order a size to fit your application----might have to change the upper and lower brackets to accomadate the thickness but other than that I don't see why this wouldn't work.
V6 cars have the battery on the passenger side. Therefore it needs to have a bracket on that side for the battery hold down to hook into. Ive seen them with the hold down on the driver, passenger, and both sides. Also, the A/C cars have a hose that bolts to the top of the support. Id imagine the only difference is a hole for the bolt to go thru.
jensenracing77
January 25th, 2018 04:16 PM
