65 Cutlass core support
Old Dec 31, 2011 | 02:31 PM
therobski's Avatar
I may need to buy a 65 ( not 64 they are NOT the same) core support for my 64 F-85 pro-touring build. I have discovered that the 65's are 3 inches longer-deeper in the cradle where the radiator sits. I live in Dallas would like to find a rust free within driving distance. Without it I may not have enough cooling space for the BB 425.
Old Dec 31, 2011 | 05:14 PM
2blu442's Avatar
If you don't find one local I've got one up in Oregon. Somewhere I was told the 6 cylinder and 8 cylinder engine equipped cars had different core supports in 1964 and 65. Does that sound familiar to you? John
Last edited by 2blu442; Dec 31, 2011 at 05:15 PM. Reason: Did finish my thought...
Old Jan 1, 2012 | 06:37 AM
66400's Avatar
4 different part #'s listed for 64
6cyl 3000122
6cyl with Air Cond 3000126
8cyl 3001445
8cyl with Air Cond 3001446
3 different part #'s listed for 65
65 3005245
65 with Air Cond 3005243
65 with 442 option 3005241
Possible radiator mounting issues between them? Henry
Old Jan 1, 2012 | 07:06 AM
therobski's Avatar
I think some of the difference maybe to is that the brackets that bolt to the bottom of the core support to hold the radiator in are different sizes to hold the correct radiator in place. I have to different sizes one you see in place is three inches wide, and I have another pair that is 2.5 inches wide. But with A/C and a trans cooler plus a 500 HP 425 I don't think the 64 core support has enough room-air space. I will start calling tomorrow. I know that a 65 core support with aluminum radiator with a shroud and 2 electric fans will work. If that is the case I will either have to modify the one I have or start over and locate a 65.
Old Jan 2, 2012 | 07:22 AM
ferndaleflyer's Avatar
I got one of the aluminum radiators from Summit that bolt (set) right in and have never had a cooling problem. And this is a .30 over 455 w/11 1/2 to 1 compression. 160 thermostat
Old Jan 2, 2012 | 07:40 AM
therobski's Avatar
Ferndaleflyer, would please provide some detail, Is this in a 64 core support?
Old Jan 2, 2012 | 07:50 AM
No it is a 65 but they list all manner of configurations. You just order a size to fit your application----might have to change the upper and lower brackets to accomadate the thickness but other than that I don't see why this wouldn't work.
Old Jan 2, 2012 | 08:01 AM
TK-65's Avatar
V6 cars have the battery on the passenger side. Therefore it needs to have a bracket on that side for the battery hold down to hook into. Ive seen them with the hold down on the driver, passenger, and both sides. Also, the A/C cars have a hose that bolts to the top of the support. Id imagine the only difference is a hole for the bolt to go thru.
Old Apr 8, 2012 | 05:52 AM
HonestDave's Avatar
Hello therobski,
Just wondering, how did you solve your core support issue?
Dave
jensenracing77
Jan 25, 2018 04:16 PM
rcktdoc
Jul 14, 2014 12:38 PM
helm42
May 22, 2008 07:51 PM
tarheeldoc
May 14, 2008 06:10 AM
esisson
Jan 14, 2007 04:38 PM
