64 Cutlass. Printed Circuit Panel for Dash lights & Plug for Fuse Box
Hi
I am looking for the printed circuit panel that goes behind the dashboard that controls the dash lights. (picture attached) I am also looking for the
connector plug that goes into the back of the fuse box under the dash. Please let me know if you have any of these working parts
Look up a local Motorola Repair center if there is one in your town. When I worked for COMMENCO Inc. in Kansa City there were two of us technicians who had the micro repair capability, using a microscope to fix printed circuit boards, runs, crack in the substrate, multi level, etc. The repair of your board would be a very, very easy fix for someone with the materials, skill and the tools to do so. Our labour charge was $120.00/hr back in the nineties, not sure what the going rate is now but I bet you could get it repaired for less than two hours of labour. Of course, if you can find a replacement for less then go for it but that is always an option if that is only one you have.
As Dan suggested (Post #2) this may be a relatively easy & quick fix - esp. "if" the issue resides where the arrow points. It appears there may be a break in the foil. A pretty simple easy fix.
