425 pistons
Standard bore ,cast or forged high compression without rods and Akron Ohio.
[QUOTE=ROCKETMAN269V;791312]Cast, forged; standard or over bored; low, high or ultra high compression; with or without rods; location? I can help with some of the options listed. Thanks, Bob
$404 a set
all the way back to the '61 425 [jeeeez]
http://egge.com/product/list.php?q=p...Filter+Results
I have whole motor for sale I'm just over west side of ohio line. complete motor 250.00 that's cheap. here is link on here https://classicoldsmobile.com/forums...lds-425-a.html
That is what I asked the site to look up; other versions possible?
I think the non-running D block / C heads Toro 425 at $250 is a BARGAIN.
MD, the "search" link returns nothing for me also.
Bloody weird.
System must use that code number in the URL in conjunction with a short-duration cookie, because it won't work for me either.
Anyway, why not search "425 pistons"? (actually, it's the same as searching "pistons," because the board automatically ignores numbers, which, as you might imagine, is a brilliantly useful feature on an automotive forum )
If you do, this thread comes up 2nd after yours (it's the first hit if you search in "Parts for Sale").
This thread comes up about halfway down, and this thread comes up about a quarter of the way down.
That is a good deal well my brother will be driving and I don't know if he wants to drive that far if I had my own truck I would
And likely short on compression height like all other aftermarket cast pistons. Egge won't give you any specs to verify that, though (I called and asked), but a member measured a set of their pistons and reported back ~.020" shorter than factory spec.
pfft
I put two Olds 350's in the back of a Dodge caravan.
'most any vehicle will haul ONE engine. Take the heads and intake off...
