425 question about con rods and pistons
Old May 5, 2010 | 04:06 PM
olds425's Avatar
I have a '66 425 block with a 455 crank and 7 inch rods and a piston pin height that matches a 455. This engine was free. It appears that it has 425 rods with 455 pistons and crank. Why would someone do this? Any ideas are welcome, I think from what I have been reading this would put the piston close to zero deck. If this is so, why are more people not doing this.? I can't understand why anyone would do this otherwise. I will attach pics of what I hope to install it in.
Old May 5, 2010 | 09:19 PM
88 coupe's Avatar
Junior Member
Originally Posted by Olds425
........ this would put the piston close to zero deck ........
Simple math. The hard part is knowing which numbers to use.
The .125" difference in Pin (compression) height between the 425 (1.615") and 455 (1.740") was to compensate for the .250+" stroke and .265" Rod length increases.
Simple answer: At TDC, your pistons would be about .250" out of the hole.
Norm
Old May 6, 2010 | 04:38 AM
507OLDS's Avatar
The 455 pistons will be too tall with the 455 crank/7" rod combo.Here are your options:
455 crank,455 rods,455 pistons
455 crank,7" 425 rods,shorter piston(I have used a set of 455 Pontiac pistons for this combo,but there are others).
When installing a 455 crank into a 425 block,you will need to notch the bottoms of the cylinders,just as they did with the 455 blocks,to clear the additional stroke.
Using the longer rod reduces rod angle,& gives you a shorter,lighter piston at the end of the rotating assembly.
If you end up just wanting 455 rods,I have some,& I would be interested in your 425 rods,if you want to part with them.
Old May 6, 2010 | 07:22 AM
olds425's Avatar
Thanks for the answers. I will think about trading the rods with you. thanks for the quick responses. The car is a '42 Chevy, kind of nice to have an Olds in it.
Delmont 88 PA
Jul 23, 2014 05:19 PM
f-85
Sep 26, 2012 11:18 AM
coldwar
Tech Editor's Desk
Aug 17, 2010 04:18 PM
DAN76
Mar 18, 2009 04:36 PM
shaks 442 clone
May 31, 2007 08:42 AM
