405442 19" Fan Assembly
Old May 2, 2020 | 04:36 PM
jharsh's Avatar
405442 19" Fan Blade Assembly
Noticed my Rallye has the wrong Fan Assembly installed So, I am looking for a good quality 405442 19" Fan Blade Assembly.
Thanks,
Jim
Old May 2, 2020 | 06:00 PM
442crzy's Avatar
PM sent
Old May 2, 2020 | 06:33 PM
rocketscientis's Avatar
Th
Think my fans & clutches spacers fastners & water necks are all listed under BBO water pumps for sale..or i can email u pix ...have a low milage oai unit that was removed from a hurst before it became a drag car & a selection of others as well
in lansing Michigan
Old May 3, 2020 | 04:17 AM
jharsh's Avatar
in lansing Michigan
SO, let me get this straight, you what me to look through your for sale ads for a Water Pump ads to see if you may have a fan for sale. Really, and where in this ad did I say I wanted a OAI Unit. Please do not put your spam in my ads.
Old May 3, 2020 | 08:55 AM
Usualy A what did you say inqueery is followed up with.....
Usually that type of question is answered
with , " what I said was that if you pay attention you won't feel stupid but in your case perhaps we should make an exception" however due to so-called modern technology I'm afraid I'm going to have to somehow alter that and include something about voice text
picture of fan you do not want...dont currently have 4 blade images (pictures) for you
Old May 3, 2020 | 09:29 AM
Straighten up fly right
If you are no longer bent , & orientation is hetero
& you understand that this item pictured is not what you are suposed to buy then there is a possibility someone might refer to you as straight or straightened or straightly
and you have a firm grasp of the concept that the straightest distance between two points is a line you may be on the same page and that is good enough if you eventually catch up to the paragraph sentence and word that'll be fine too
When I find that there is confusion the first thing I do is to check and then double-check make certain absolutely without a doubt that I myself I am not the idiot in the conversation but a mystery is sometimes a decent read so I have foregone that & sent you a picture of the fan that you are not after and water pump that you are not as well I hope this helps with getting things straight , would you like to see a picture of a very nice 1970 fan shroud that you are not after as well....correct answer shold be of negative response ,as your last reply was to maintain straightness
but you lead if ya want..been long way up the hill a time or two....
Thanks , maybe
Jon
Old May 3, 2020 | 09:31 AM
Say WHAT
SO, let me get this straight, you WHAT me to look through your for sale ads for a Water Pump ads to see if you may have a fan for sale. Really, and where in this ad did I say I wanted a OAI Unit. Please do not put your spam in my ads.
you will have to forgive me for initially overlooking WHAT appears to be an honest mistake a fat thumb or the same voice txt I use but I suspect is a representaion of a much deaper issue ......... The only thing did I WANT you to do , will be to get the right fan for your car , or one that makes you happy ...luck with both...that is what I would want you to do either lies within your realm of possibilities & a couple more mistakes would be nice as they tend to cut oneself back down to size
actually hold off I found another one you may have reached your quota when asking for a fan for a car that has o a i I believe that was when you somehow implied you wanted to an oia fan , if you know the subtle differences in fans and I must assume that a person with your vast knowledge and superiority would , then I don't have to explain it again but I will point out not a bad idea 2 proofread your texts before you send it as well that OAI is not a manufacturer or a brand name it stands 4 outside air induction commonly found on W 30s Hurst Oldsmobiles and the cute ones with little small-block in them too
Old May 3, 2020 | 09:59 AM
Checked & double checked
And wouldn't you know it you are looking for a four bladed fan direct mount I wich I have a few but don't believe I have a current picture of
wouldn't you know it apparently it's high time I get an image of 1
​​​​​​ and yourself as well if that is what you are looking for in order to ascertain whether or not it meets your stringent requirements an email address is always helpful in these matters
Old May 3, 2020 | 10:02 AM
Or i can email you pix
in lansing Michigan
Old May 3, 2020 | 10:20 AM
in lansing Michigan
perhaps either of us could have better lead with emailin pics of my selection of various & assorted 30 year collection compiled by two people & their assistants...not suggestin any did anything wrong as thats been coverd I believe..... Just sayin...
to reitterate ( say again)...you can view fans that could be purchased by you , already loaded at this site , or image transfer (pictures) can be viewed by you if I email them to your email address
and believe I may have left out the fact that four four two crazy has the best fan for your car at thee best price that can't be beat and you sir should by all means buy his fan immediately thank you
Old May 4, 2020 | 02:51 PM
jharsh's Avatar
Found what I needed. Thanks
goldie442
Aug 9, 2014 08:11 AM
midrange
Apr 22, 2014 02:02 PM
71Convertible
Dec 14, 2012 04:23 PM
jdana24
Mar 22, 2012 09:26 PM
SX455
Oct 31, 2007 09:13 PM
