400 E crank wanted
Old May 24, 2020 | 11:40 AM
67red442discragtop's Avatar
400 E crank wanted
Needle in the haystack
diamond in the rough
same ol story
In need of finding std shift 400 E crankshaft for sale
Old May 24, 2020 | 12:01 PM
You might have better luck posting in the Parts Wanted section rather than dredging up a five year old thread. I've moved you to your very own thread now. FYI, all 1965-67 BBO short stroke cranks interchange - early 400s and 425s use the same 3.98" stroke and all are forged. Your machine shop can machine the pilot bearing hole in an AT crank.
Old May 24, 2020 | 12:07 PM
looking for E Block crank...any help appreciated
Old May 24, 2020 | 12:11 PM
Thanks Joe
My car and computers skills are lacking
Old May 24, 2020 | 12:18 PM
ROCKETMAN269V's Avatar
400 E crank wanted
I have a couple early (400/425) cranks. I have one fresh from the machine shop; I believe that it is a stick crank. I will check. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old May 24, 2020 | 05:59 PM
2blu442's Avatar
If Rocketman269V only has automatic crankshafts you can have a machine shop cut it for the pilot bearing/bushing. I had this done several years ago and not a big deal for a competent machine shop. There's a couple old threads here that have the dimensions of the hole needing cut, I printed that off and took it in with the crank. That may be easier than locating one that's already setup for a manual transmission. Just a thought, John
Old May 24, 2020 | 09:01 PM
RAG's Avatar
RAG
I just had my local machine shop cut crank to spec for bearing and they charged me $200. 25 years ago same shop charged $46.
Old May 24, 2020 | 09:33 PM
65-67 E block crank 384 722 std trans
Thank you for the suggestion. I'm feeling better about the block getting back into its A body. I'm hoping to find std crank and avoid the search for a shop to machine the hole in that steel. I'm hoping the black cloud that has followed this car soon will go away like we want this virus to do. It's the 1st car I've ever owned that has been a pain like I've never experienced. Now I understand what it feels like to own a problem.
An early thank you to the ones who years ago posted the machining specs. I'm certain I got to go a lil way out of this town to locate the " competent machine shop " so I don't have to cut the input shaft.
Old May 24, 2020 | 09:35 PM
Machine, bits and a lot of skill
Old May 25, 2020 | 10:30 AM
I have two 400/425 cranks. Email me direct: drolds1@bellsouth.net. Thanks, Bob.
Old May 25, 2020 | 11:31 AM
JRSL69's Avatar
J.R.
I'm thinking they just have to drill a hole deep enough for the pilot shaft and then use an after market bearing that fit the torque converter hole instead of using the manual bushing.
37OldsCoupe
Feb 3, 2019 10:53 AM
steedaq
Mar 27, 2013 07:56 PM
David H
Dec 31, 2012 06:03 PM
dmcianfa
Sep 17, 2010 11:40 AM
66cv442
Jul 25, 2009 06:34 AM
