394 project
They are rarer than hen's teeth .
In the more than 50 years that I have been around Oldsmobile 394's.
I have never seen or heard of an aluminum aftermarket four barrel manifold .
Just two four and 3 x 2 manifolds .
Offenhauser still makes 2 X 4 and 3 X 2 manifolds on special order through Exeter Auto Supply .
Used Weiand 2 X 4 manifolds frequently appear on E-Bay .
I'm going to use a 1958 371 ( high compression ) harmonic balancer on my 394 if it will work !? I haven't started this engine and won't be for a while so I hope it'll do. It fit on the 394 crank nicely.
May not be the same .
The part numbers are different , so there is obviously some difference in them .
In fact there are different numbers for almost every year from 58 thru 62 .
