350 heads
Old Nov 6, 2016 | 02:15 PM
edegraaf's Avatar
350 heads
I am looking for early 350 heads for a 403 olds engine build. I am located in Hoosick Falls , NY (Albany area)
Old Nov 6, 2016 | 05:18 PM
olds403's Avatar
What is your budget? Have 4's and 5's. Heads will be magged.
Bare castings. Not Going to give them away, but good stuff
Old Nov 7, 2016 | 06:36 AM
ROCKETMAN269V's Avatar
350 heads
I have several sets of early small block and big block heads. The head bolt holes will need to be opened up for 1/2" head bolts on any early heads that you get. I can have a set ready to bolt on if you like, or just sell you cores. I sent a set, all done, to a member here for his 403 and he is very happy with the results. Email me to discuss: drolds1@bellsouth.net. Thanks, Bob.
Old Nov 7, 2016 | 10:09 AM
I would read Mark's thread about "C" heads on a 403.
Old Nov 7, 2016 | 11:05 AM
olds403's Avatar
If on a trans am BB heads and rpm intake will not work with shaker hood. Can be done with mjds
Old Nov 7, 2016 | 12:41 PM
No difference between small block and big block heads, as far as any clearance issues are concerned.
Old Nov 7, 2016 | 03:02 PM
His point was that the BBO heads on a 403 require an intake with enough meat to allow porting to match the heads. The Performer RPM is the most common intake used with this combo, and it will not allow the shaker scoop to clear.
Of course, first, the RPM is not the ONLY intake that will work. I believe the out of production OL4B has enough meat, as do several stock iron intakes.
Second, the OP didn't say this was going in a Trans Am, so this whole tangent may be moot.
Old Nov 7, 2016 | 03:19 PM
edegraaf's Avatar
this is for a firebird Formula, no shaker hood.
lunaboy
Sep 24, 2018 10:15 AM
Cpriester123
Aug 15, 2016 01:52 PM
olds4life
Dec 25, 2012 12:56 AM
gearheads78
Nov 10, 2009 09:31 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
