1977 Cutlass Backup Light Lens Needed
I use 1977 backup light lenses in my '76 Cutlass Salon coupe because they allow more light to be projected . . . and yesterday one fell out and was lost! This is, unfortunately, not the first time this has happened . . .
Attached is a photo of what I need. Lettering at bottom reads "DOT (2) R77". I will take just the lens, or a whole '77 unit if someone has one.
I plan to install the lenses with white silicone seal from now on (for better shock resistance) . . . unless someone has a better idea.
Jeff
Jeff
Does anyone have a part number for these lamp units? I could use it to search for what I need. I don't suppose that the lens itself has a part number (couldn't find one) and the lamp units themselves are a very tight fit and bit of a pain to remove and install; truthfully, I think that R&R-ing them to replace my rear license plate filler is what caused the one lens to fall out in the first place.
Jeff
Jeff
Gary,
IIRC it seems that the '76 lenses were less transparent, hence less able to project light than the '77s. There is a visual difference in the opacity when the two years are compared side-by-side.
At this point, I would take a set of '76 pieces just to be able to get something to cover the one that's missing the lens . . .
Jeff
Jeff
I have the '77 backup lights and I don't see any way of removing the lens without damaging it. The ones I have are good enough for a daily driver, however each of the four I have has a small corner chipped off ( a little strange?) It would be hidden once installed. Can send pix if you are interested.
Dave
Dave
Jeff
Jeff
76 lense , of the 4 sides it has 2 sides that are extended about a quarter inch . If you put both pictures together you will see the difference .
As there was 2 style of housings . I have also found 3 different sets of the stainless trim that surrounds the the gas compartment .
Jeff
Jeff
jaunty75
April 12th, 2015 05:53 PM
