1977 Cutlass Backup Light Lens Needed
Old Apr 10, 2016 | 01:37 PM
76CutlassSalon's Avatar
I use 1977 backup light lenses in my '76 Cutlass Salon coupe because they allow more light to be projected . . . and yesterday one fell out and was lost! This is, unfortunately, not the first time this has happened . . .
Attached is a photo of what I need. Lettering at bottom reads "DOT (2) R77". I will take just the lens, or a whole '77 unit if someone has one.
I plan to install the lenses with white silicone seal from now on (for better shock resistance) . . . unless someone has a better idea.
Jeff
Old Apr 12, 2016 | 05:46 AM
Does anyone have a part number for these lamp units? I could use it to search for what I need. I don't suppose that the lens itself has a part number (couldn't find one) and the lamp units themselves are a very tight fit and bit of a pain to remove and install; truthfully, I think that R&R-ing them to replace my rear license plate filler is what caused the one lens to fall out in the first place.
Jeff
Old Apr 12, 2016 | 11:28 AM
zodiacblue442's Avatar
What's the difference between 76 and 77 backup lenses? I know the front park/turn signal lenses are different but I didn't know there was a difference in the backup lenses.
Old Apr 12, 2016 | 11:37 AM
Gary,
IIRC it seems that the '76 lenses were less transparent, hence less able to project light than the '77s. There is a visual difference in the opacity when the two years are compared side-by-side.
At this point, I would take a set of '76 pieces just to be able to get something to cover the one that's missing the lens . . .
Jeff
Old Apr 14, 2016 | 06:41 AM
oldsthunder's Avatar
I have the '77 backup lights and I don't see any way of removing the lens without damaging it. The ones I have are good enough for a daily driver, however each of the four I have has a small corner chipped off ( a little strange?) It would be hidden once installed. Can send pix if you are interested.
Dave
Old Apr 16, 2016 | 11:35 PM
allykatt 1992's Avatar
Jeff
76 lense , of the 4 sides it has 2 sides that are extended about a quarter inch . If you put both pictures together you will see the difference .
As there was 2 style of housings . I have also found 3 different sets of the stainless trim that surrounds the the gas compartment .
Old Apr 16, 2016 | 11:45 PM
Jeff
Jeff , I have taken some of the 76 lenses and cut off the 2 sides with a dremil . Filed the edge and sanded it and looked fine . I have sold a few and never had anyone say they noticed a difference between the 76 and 77 lense . But can't say for sure if there is any difference ? I have one that I could cut the 2 edges off and send to you if you haven't found one yet .
Old Apr 17, 2016 | 04:05 AM
allykatt,
Thanks, but I already purchased one from oldsthunder. If I need another, I'll keep you in mind.
Jeff
Roger60
Oct 4, 2015 02:55 PM
jaunty75
Apr 12, 2015 05:53 PM
gmiles
Oct 26, 2013 08:52 AM
1k442
Feb 15, 2013 10:44 AM
Aedwards
Jun 30, 2010 09:48 AM
