1974 Cutlass Supreme Vinyl top molding
Looking for the passenger side vinyl top metal molding that fits under the opera window and bolts to the quarter panel on the inside of the trunk. Might be called a belt molding.
ok . . . is your car a full vinyl top or half?
The side trim under the Oprah window is different depending on full or half top.
Their are 5 pieces for the half top and 8 for the full top.
exactly which pieces do you need?
It is the full vinyl top. The only piece I need is the one on the top of the right (passenger side) quarter panel, directly under the opera window. It is attached by clips and is secured to the inside of the trunk with a bolt. It is usually made of two pieces and you can see that it has a metal fastener similar to a staple holding the two piece together. I will take a picture of my broken one and post it.
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
70Post
November 10th, 2022 09:30 AM
