1973-74 Cutlass rally gauges
Old April 17th, 2020, 09:45 AM
goatwgn's Avatar
Does anyone have a cluster with the oil, temp and fuel gauges in it?? Looking to replace my idiot light unit. My car is a '74, but a '73 cluster, although not the type used in '74, would match the style speedometer I have. I believe I can also use one from a '71-'72 model, if I change I use the '73-'77 housing, and use the internals, face, and circuit board off the older unit. I have seen some on ebay, but they are a bit steep for me, price wise.
goatwgn is offline
Old April 17th, 2020, 12:59 PM
svnt442's Avatar
This is a 1974 442 with the gauges. There were 2 styles of gauge faces used, and I don't think the other one ever had gauges in that style.
Does your speedo look like this?
svnt442 is offline
Old April 17th, 2020, 03:34 PM
goatwgn's Avatar
Having trouble uploading. It registers to 120 MPH in numbers. I have seen the type that registers to 120, but is only numbered to 110, and has a white needle on it. Mine has the black needles with red tips. I cant see you pictures either. I have they other type as a spare part for the speedometer. I pulled it off a '74 Salon years ago.
goatwgn is offline
Old April 17th, 2020, 03:38 PM
svnt442's Avatar
This is the style that has the gauge set made for it.
It registers to 120 MPH in numbers.Mine has the black needles with red tips.
I have never seen gauges in this style.
svnt442 is offline
Old April 17th, 2020, 03:56 PM
goatwgn's Avatar
This is it. Saw your picture too. Looks like the second one, but of course mine doesn't have the prndl, because it is console shift.
goatwgn is offline
Old April 17th, 2020, 03:58 PM
goatwgn's Avatar
I saw some a while back for a '73 442 that were in this style.Very rare I believe.
goatwgn is offline
Old April 17th, 2020, 04:02 PM
goatwgn's Avatar
I do have a speedometer off a '74 Salon, in that other style, I could switch to match the rally gauges.
goatwgn is offline
Old April 17th, 2020, 04:04 PM
goatwgn's Avatar
goatwgn is offline
Old April 17th, 2020, 04:15 PM
svnt442's Avatar
OK, I found what you're looking for, but it's in a 73 H/O.
svnt442 is offline
Old April 17th, 2020, 04:25 PM
goatwgn's Avatar
Yes. That is the one I was talking about. Very cool looking. I saw one not to long ago, but they stated it may not work, and they wanted $300 for it. It was likely worth it, but I couldn't bring myself to do it, with a question as to whether it worked or not. In retrospect, even if it didnt work, I could have repaired it with 1968-72 parts, but that would have doubled the price. Wish a company made one for these cars, in the original style. I dont like the digital ones.
goatwgn is offline
Old April 17th, 2020, 04:29 PM
scrappie's Avatar
I have these with the other speedo too if needed?
https://classicoldsmobile.com/forums...speedo-143952/
scrappie is offline
Old April 17th, 2020, 05:24 PM
goatwgn's Avatar
I appreciate the offer. That one goes to a '75-'77 though. It has the "unleaded fuel only" on it. The '73-'74 just says fuel. I will keep it in mind. I may be able to find a '74 face for it
goatwgn is offline
Old April 18th, 2020, 10:53 AM
Bill G's Avatar
i might have something for the 74..was going to change my salon to gauges at one time, but prob won't do it now..i bought a few over the years..will see if i can dig em out..
Bill G is offline
Old April 18th, 2020, 12:04 PM
Summerof84's Avatar
If I remember correctly, the wiring for 70-72 is different from 73-77.
I thought I had the correct pin wiring layout for 73-77, might have been on my Win7 PC and be gone.
Summerof84 is offline
Old April 18th, 2020, 12:28 PM
goatwgn's Avatar
Found this in my stash today. It will match rally gauges.
goatwgn is offline
Old April 18th, 2020, 05:32 PM
Bill G's Avatar
that's the same speedo as the salon..supreme had the 120 on it..
Bill G is offline
Old April 19th, 2020, 06:13 AM
goatwgn's Avatar
Yes. It came out of a '74 Salon
goatwgn is offline
Old April 25th, 2020, 09:24 AM
Bill G's Avatar
here are the pics of the one I have
Bill G is offline
Old April 25th, 2020, 09:32 AM
Bill G's Avatar
Better pic of back
Bill G is offline
Old February 27th, 2021, 01:45 PM
Gerald Nickels's Avatar
Did check your light switch left and right turn ?
Gerald Nickels is offline
Old January 24th, 2022, 05:52 PM
CutOvers Olds Parts Guys
Bee Saint Louis's Avatar
I have a 1973 Cutlass 442 Hurst Olds fuel oil temp gauge 4 sale if you’re interested
I have this gauge for your 1973 Hurst Olds for sale $300 condition unknown. (Top pic for reference)
Bee Saint Louis is offline
Old August 4th, 2022, 06:05 PM
Tfitz's Avatar
Bumping this thread. Just installed a 1973 442 Rallye Pack gauge in a ‘73 Vista Cruiser. The wiring needs to be swapped around on the connector as the Rallye Pack gauge uses the same wires as the idiot light gauge, but in a different order. It’s shown in the chassis service manual. Very easy game of connect the dots (the Rallye gauge does not use the black ground wire on the harness for some reason). Also installed brand new AC Delco temp and oil pressure sending units.
I have mine installed and all wired in nicely. When I crank the car, my temp gauge needle shoots over and maxes out while I’m cranking. Is this normal behavior for these gauges?
Tfitz is offline
Old August 5th, 2022, 04:19 AM
goatwgn's Avatar
I cannot remember which, I will need to check, but I believe it is a small green wire on the ignition switch you can disconnect to keep this from happening.
goatwgn is offline
Old August 5th, 2022, 04:25 AM
Tfitz's Avatar
Do they do this from the factory? If they do, it’s fine and I’ll leave it alone. If it’s not being grounded properly or something, then I need to diagnose that.
Tfitz is offline
Old August 5th, 2022, 10:56 AM
goatwgn's Avatar
Yes, they do.
goatwgn is offline
Old August 5th, 2022, 11:13 AM
Tfitz's Avatar
Yes, they do.
Thank you for the info. I’ll leave it alone then!
Tfitz is offline
Old August 7th, 2022, 10:21 AM
Tfitz's Avatar
I can’t seem to get the oil pressure needle to work. It is always maxed out when the car is running.
It has a new AC Delco oil pressure sending unit, and I have a new clean spade connector attached to it.
The wire has 9V running to the sending unit, and the sending unit has a good ground connection to the block. I have it screwed in tightly.
The sending unit shows 0 ohms. Bad sending unit?
Tfitz is offline
Old August 7th, 2022, 10:47 AM
goatwgn's Avatar
if the sending unit has no resistance, it is likely bad. I would check it against another.
goatwgn is offline
Old August 7th, 2022, 10:51 AM
Tfitz's Avatar
I’m pulling this one and returning it for a 442-style sending unit (the large one that requires the extension/adapter). Those are meant to be used with a gauge, whereas the one I purchased is supposed to be for idiot lights. I think that is my problem. Anybody know where I can get the oil pressure adapter/extension? I can’t find one anywhere online for some reason.
Tfitz is offline
Old August 7th, 2022, 11:18 AM
goatwgn's Avatar
That is definitely the problem. I would check Inline tube for the adapter. I believe that is where i got mine.
goatwgn is offline
Old August 8th, 2022, 12:21 PM
  #31
pizza442's Avatar
If I remember right, there is a sending unit for gauges that read 80psi at max and a diff unit for 60 psi max. Someone correct me if I'm wrong but I think the 69-72 is diff from the 72-77, or is it the 78-88?
pizza442 is offline
Old August 16th, 2022, 04:30 AM
  #32
Tfitz's Avatar
The idiot light sending unit was indeed the issue.
The correct part is the larger AC Delco D8034 sending unit. You will need a brass sending unit elbow usually sold as a 68-72 part, which bolts right up to my ‘73 350 with no issues. I didn’t use any thread tape, just made sure it was extremely snug. Zero leaks.
Hope this info helps someone else in the future.
In conclusion for using the 1973 442 gauge on a normal Cutlass: rewire your gauge cluster connector, use the larger sending unit and elbow. Probably a good idea to get a fresh temp sending unit as well.
Apparently you can disconnect wires directly from the connector by using a small flat head screwdriver, but I didn’t want to do that and risk breaking any plastic on the connector, so I just snipped the wires and re-did it with electrical twist caps. It’s a tight fit, but more than secure enough and totally reversible.
Tfitz is offline
April 10th, 2019 06:11 PM
damnolds
May 23rd, 2016 09:29 PM
zodiacblueS
January 6th, 2012 05:11 PM
curvewrecker
July 4th, 2010 09:36 AM
Olds luvr
January 26th, 2010 01:49 PM
Quick Reply: 1973-74 Cutlass rally gauges
