1970 TCS switch bracket - intake bolt and nut
Old April 5th, 2021, 06:45 AM
BSiegPaint's Avatar
BeenThere has taken care of me - thanks again, Bill
BSiegPaint is offline
Old April 5th, 2021, 10:03 AM
442crzy's Avatar
PM sent
442crzy is offline
Old April 5th, 2021, 01:47 PM
Factoryhotrod's Avatar
Originally Posted by BSiegPaint
I need that single double-headed bolt that attaches the TCS switch bracket to the intake manifold, and the nut that holds the bracket on. Seems as if no one makes a reproduction, or I don't know how to search properly. I would entertain a 455 TCS bracket as well, as mine is kinda beat up. Let me know what you might have!
Thanks!
Bob
Factoryhotrod is offline
Old April 6th, 2021, 05:11 AM
BeenThere's Avatar
bracket
Bob, if this is what you need let me know. I will send it to you, no charge. Bill
BeenThere is online now
Old April 6th, 2021, 04:23 PM
BSiegPaint's Avatar
Bill, that’s exactly it. I will send you something for that for sure. Thank you!
Old April 6th, 2021, 07:01 PM
v8al's Avatar
Cool that's service!
I just checked mine and it's missing the same double headed bolt.
Curious if this is the same bolt as the lower water pump / power steering stud which is available.
v8al is offline
Old April 6th, 2021, 08:01 PM
70Post's Avatar
No - it's not the same. The lower water pump/power steering stud is much longer on the forward/"outside" half and about half of that length is smooth/unthreaded. The threaded forward/"outside" portion on the correct stud is only 1/2"-5/8" long/tall (measuring an original here). \
Here's another thread on this site where these were discussed:
https://classicoldsmobile.com/forums...t-stud-151675/
70Post is offline
BSiegPaint's Avatar
I was looking at that exact comparison and I think the water pump bolt is a thread size smaller and a half inch or more longer. 5/16" compared to 3/8" threads (my memory may fail me here). Are the top and bottom threads on the water pump the same size? The correct bolt here has the same size threads on both ends.
EDIT - Patton beat me to it lol
Jon442
November 25th, 2020 02:20 PM
Cutlasskyle
Brakes/Hydraulic Systems
August 30th, 2017 07:44 AM
Olds24
July 28th, 2014 06:55 AM
442craig
February 18th, 2014 05:44 PM
Del70
July 11th, 2011 09:10 PM
Quick Reply: 1970 TCS switch bracket - intake bolt and nut
