1970 TCS switch bracket - intake bolt and nut
Old Apr 5, 2021 | 06:45 AM
BSiegPaint's Avatar
BeenThere has taken care of me - thanks again, Bill
Old Apr 5, 2021 | 10:03 AM
442crzy's Avatar
PM sent
Old Apr 5, 2021 | 01:47 PM
Factoryhotrod's Avatar
Originally Posted by BSiegPaint
I need that single double-headed bolt that attaches the TCS switch bracket to the intake manifold, and the nut that holds the bracket on. Seems as if no one makes a reproduction, or I don't know how to search properly. I would entertain a 455 TCS bracket as well, as mine is kinda beat up. Let me know what you might have!
Thanks!
Bob
Old Apr 6, 2021 | 05:11 AM
BeenThere's Avatar
bracket
Bob, if this is what you need let me know. I will send it to you, no charge. Bill
Old Apr 6, 2021 | 04:23 PM
BSiegPaint's Avatar
Bill, that’s exactly it. I will send you something for that for sure. Thank you!
Old Apr 6, 2021 | 07:01 PM
v8al's Avatar
Registered Olds Owner
Cool that's service!
I just checked mine and it's missing the same double headed bolt.
Curious if this is the same bolt as the lower water pump / power steering stud which is available.
Old Apr 6, 2021 | 08:01 PM
70Post's Avatar
No - it's not the same. The lower water pump/power steering stud is much longer on the forward/"outside" half and about half of that length is smooth/unthreaded. The threaded forward/"outside" portion on the correct stud is only 1/2"-5/8" long/tall (measuring an original here). \
Here's another thread on this site where these were discussed:
https://classicoldsmobile.com/forums...t-stud-151675/
BSiegPaint's Avatar
I was looking at that exact comparison and I think the water pump bolt is a thread size smaller and a half inch or more longer. 5/16" compared to 3/8" threads (my memory may fail me here). Are the top and bottom threads on the water pump the same size? The correct bolt here has the same size threads on both ends.
EDIT - Patton beat me to it lol
Jon442
Nov 25, 2020 02:20 PM
Cutlasskyle
Brakes/Hydraulic Systems
Aug 30, 2017 07:44 AM
Olds24
Jul 28, 2014 06:55 AM
442craig
Feb 18, 2014 05:44 PM
Del70
Jul 11, 2011 09:10 PM
