1970 455 W-30 Motor
Old Feb 13, 2014 | 03:31 PM
Oldracerjones's Avatar
1970 455 W-30 Motor
Serious inquiry into a 455 W-30 motor for my replica. Regardless of condition as long as it is recoverable.
Old Feb 13, 2014 | 03:45 PM
jensenracing77's Avatar
What are your goals? All you really need is a set of F heads and a W455 aluminum intake and put them on any 455. If you are looking for the exact thing you would also need a correct carburetor and distributor. I would not use an original W-30 cam or pistons. If you are building a "replica" I would at least update the cam and pistons to something more modern and not worry about the numbers correct carb and distributor.
Old Feb 13, 2014 | 03:46 PM
Also, Contact Vader, He is a member here. I think he has most of the parts you need.
Old Feb 13, 2014 | 04:51 PM
W-30 455
I appreciate the input. It has a 68 370 hp 455 (according to seller) it is a 455 with C heads. The engine sounds good and has some power but doesn't have the sound of my old W-30 motor.
I understand the F heads flowed the best of stock olds heads, so that makes sense to me. I also understand the cam and pistons comment, new technology can improve the performance. It has an edelbrock performer manifold now with a quadrajet on it.
Guess I just néed to evaluate what I have; compression check, etc. If it's solid, follow your advice, and build me a replica motor.
Thanks.
Old Feb 13, 2014 | 05:21 PM
Texas442's Avatar
1971 442 conv
You may also get a clone that is already done. There are a lot of them available now a days.
Old Feb 13, 2014 | 05:30 PM
Differential
Originally Posted by joesw31
an idea is that you can get a set of "f" replica heads, replica w-30 intake, and if you really liked your old w30 camshaft that can be purchased as well. Do you know the gear ratio of your differential?
3.91
Old Feb 13, 2014 | 08:06 PM
507OLDS's Avatar
The F-heads do not outflow the other castings. They are all about the same.
Old Feb 14, 2014 | 12:47 AM
nsnarsk65cutlass's Avatar
Maybe flow wise not price wise.
Old Feb 14, 2014 | 04:51 AM
507OLDS's Avatar
Correct. If you just need the look,take an E and grind the lower leg off. You will save about $2500.00,which you can use to buy parts that will make more power,or to have the heads ported.
Old Feb 14, 2014 | 07:03 AM
Rusty Boltz's Avatar
w-30 motor
In Reno, Nevada craigslist is a listing under Olds that advertises a 1970 W-30 motor. It has incorrect block, but has F heads and the intake. Guy wants $10,000 for it which seems a little steep. Good luck!
Old Feb 14, 2014 | 08:02 AM
Working It
I appreciate the input but don't need the look. The car is a replica because I can't afford the real thing yet but I don't want to work anything to make it look real. Just want something to drive and go to local cruises.
Old Feb 14, 2014 | 09:48 AM
507OLDS's Avatar
Good F-heads are at least $2500.00,and they don't make any more power than a C-head,if they are both stock.
What car do you have?
Old Feb 14, 2014 | 11:26 AM
4speed455's Avatar
If you don't need the look of the original F heads and your just after performance keep your C heads. Like others said they all flow about the same. Unless the 68 455 was out of a toronado it will probably have small valves though.
Old Feb 14, 2014 | 01:09 PM
RetroRanger's Avatar
72 Olds CS
??? what are you hoping to do ??? a w-30 engine (or car) costs real money. If your just after the sound that can be taylored w any number of changes to any 455
IMO work the 455 you have to what you want !!!
BLACKCADDY
Jun 2, 2015 09:38 AM
charlierogers
Oct 14, 2011 09:44 AM
dp442
Feb 15, 2011 04:22 PM
ctrain22
May 20, 2009 11:02 PM
Giddy
May 12, 2009 08:21 PM
