Looking for an engine from a 1970 442 with a 455 block. Let me know what you have. Would like an early build 455 block with Julian date of 300 and #3 on it from a 70 442, but will take what I can get. If its a 4 speed block (crank), even better.
Even a station wagon or Cutlass SX has the engine you need now finding a early one might be a problem to find. But a 455 block with E heads or F heads will work. I once found a set of F heads on a 1971 wagon with a 455 motor. Good luck. I just bought a 455 STD bore I will check date I'm in Nor Cal.
