1970 442 fender fillers
Old July 15th, 2012 | 04:10 PM
bentlyf1's Avatar
i'm looking for a nice used set of front fender fillers for my 1970 442,
Old July 15th, 2012 | 04:15 PM
DENT's Avatar
Do you mean the part around the headlight?
Old July 15th, 2012 | 04:20 PM
btrbill's Avatar
I think he means the metal piece in the front inside of the fender that is screwed on... But I could be mistaken!
Old July 15th, 2012 | 06:08 PM
bentlyf1's Avatar
Sorry for the confusion not sure what that correct name for the part is but the part i'm looking for is the metal piece thats inside the fender and screwed on. like btrbill said
Old July 15th, 2012 | 06:16 PM
btrbill's Avatar
I may have a left one from a good fender a tree fell on. Let me look and I will check its condition.
Old July 15th, 2012 | 06:21 PM
I think he's referring to what most of us call an inner liner? GM called them fillers. The 70-72 filler plates were plastic though.
Old July 15th, 2012 | 07:40 PM
70Post's Avatar
I think he means the "L" shaped metal pieces that hold the front of the fender to the outer top edges of the core support.
Also.....you better check and see if there's a difference b/n the '70 versions and the '71/2's. Not sure that there is but worth finding out in case there is to avoid getting the wrong part. I'll check with a guy here that has an interchange manual.
Example pic below...is this what you are looking for?
Old July 15th, 2012 | 08:46 PM
oldspackrat's Avatar
The '70 version is different from the '71/72 versions.
Old July 16th, 2012 | 06:48 AM
bentlyf1's Avatar
Thr photo that 70post has is the piece that i'm looking for and i thought that the 1970 was different then 71-72.
Old July 16th, 2012 | 10:48 AM
Olds24's Avatar
I have a nice pair from a 70, Blasted and Primed. $75 shipped.
Old July 16th, 2012 | 05:20 PM
bentlyf1's Avatar
P.M Sent
Old July 16th, 2012 | 07:42 PM
Paladin31's Avatar
Plastique....?
Allan my 70's are all metal, are 71-2's plastic? Respectfully, Brett
Old July 16th, 2012 | 08:57 PM
Brett, if you're talking about the inner wheel liners? Yes they are plastic. I'm sure the 70 was plastic too.
The part that Patton identified and was the part being searched for is metal. On all of the Cutlass lines for 70-72
Old July 16th, 2012 | 09:09 PM
Paladin31's Avatar
Ahhhh sooooo you were describing inner fender liners, I misunderstood. Yes the Part Patton Pic'd...Thought you meant the fender eybrow liners were plastic.Had me very curious. Thanks, G'day
Old July 16th, 2012 | 09:18 PM
bentlyf1's Avatar
thanks for all the information about this subject sorry if i confused people
as i was not sure what the piece's where called, I have found the correct set for my 1970 442 . Rick
nicolae788
July 22nd, 2014 06:28 PM
Rocketguy
February 16th, 2014 09:56 AM
brandon reynolds
November 28th, 2013 08:58 AM
1969camaross350
May 8th, 2013 04:22 AM
Olds
Body work
December 20th, 2011 05:54 PM
