1970 442 fender fillers
Old Jul 15, 2012 | 03:10 PM
bentlyf1's Avatar
i'm looking for a nice used set of front fender fillers for my 1970 442,
Old Jul 15, 2012 | 03:15 PM
DENT's Avatar
Do you mean the part around the headlight?
Old Jul 15, 2012 | 03:20 PM
btrbill's Avatar
I think he means the metal piece in the front inside of the fender that is screwed on... But I could be mistaken!
Old Jul 15, 2012 | 05:08 PM
bentlyf1's Avatar
Sorry for the confusion not sure what that correct name for the part is but the part i'm looking for is the metal piece thats inside the fender and screwed on. like btrbill said
Old Jul 15, 2012 | 05:16 PM
btrbill's Avatar
I may have a left one from a good fender a tree fell on. Let me look and I will check its condition.
Old Jul 15, 2012 | 05:21 PM
I think he's referring to what most of us call an inner liner? GM called them fillers. The 70-72 filler plates were plastic though.
Old Jul 15, 2012 | 06:40 PM
70Post's Avatar
I think he means the "L" shaped metal pieces that hold the front of the fender to the outer top edges of the core support.
Also.....you better check and see if there's a difference b/n the '70 versions and the '71/2's. Not sure that there is but worth finding out in case there is to avoid getting the wrong part. I'll check with a guy here that has an interchange manual.
Example pic below...is this what you are looking for?
Old Jul 15, 2012 | 07:46 PM
oldspackrat's Avatar
The '70 version is different from the '71/72 versions.
Old Jul 16, 2012 | 05:48 AM
bentlyf1's Avatar
Thr photo that 70post has is the piece that i'm looking for and i thought that the 1970 was different then 71-72.
Old Jul 16, 2012 | 09:48 AM
Olds24's Avatar
I have a nice pair from a 70, Blasted and Primed. $75 shipped.
Old Jul 16, 2012 | 04:20 PM
bentlyf1's Avatar
P.M Sent
Old Jul 16, 2012 | 06:42 PM
Paladin31's Avatar
Plastique....?
Allan my 70's are all metal, are 71-2's plastic? Respectfully, Brett
Old Jul 16, 2012 | 07:57 PM
Brett, if you're talking about the inner wheel liners? Yes they are plastic. I'm sure the 70 was plastic too.
The part that Patton identified and was the part being searched for is metal. On all of the Cutlass lines for 70-72
Old Jul 16, 2012 | 08:09 PM
Paladin31's Avatar
Ahhhh sooooo you were describing inner fender liners, I misunderstood. Yes the Part Patton Pic'd...Thought you meant the fender eybrow liners were plastic.Had me very curious. Thanks, G'day
Old Jul 16, 2012 | 08:18 PM
bentlyf1's Avatar
thanks for all the information about this subject sorry if i confused people
as i was not sure what the piece's where called, I have found the correct set for my 1970 442 . Rick
nicolae788
Jul 22, 2014 05:28 PM
Rocketguy
Feb 16, 2014 08:56 AM
brandon reynolds
Nov 28, 2013 07:58 AM
1969camaross350
May 8, 2013 03:22 AM
Olds
Body work
Dec 20, 2011 04:54 PM
