1969 Cutlass Front wheel hub - drum brake
Hi,
Looking for an original GM front wheel hub.
My car is a 1969 Cutlass Supreme, 350ci, auto trans with drum brake.
The part should be in good shape with foremost no play on the spindle.
Thanks a lot for your help!!
If 69 still used the bell type drum,the hub & drum are hard to separate. The lugs have to be pressed out and back in with a special tool. I think 69 used this type but not positive. I may have a used front unit of this type if it is. I've seen guys go to the later type hub with the removable drum if need be.
yeahbuddy
Brakes/Hydraulic Systems
January 15th, 2014 02:10 PM
