1969 Cutlass Front wheel hub - drum brake
Old Apr 30, 2016 | 02:02 PM
Christophe2m6's Avatar
Hi,
Looking for an original GM front wheel hub.
My car is a 1969 Cutlass Supreme, 350ci, auto trans with drum brake.
The part should be in good shape with foremost no play on the spindle.
Thanks a lot for your help!!
Old Apr 30, 2016 | 02:17 PM
66-3X2 442's Avatar
Originally Posted by Christophe2m6
Hi,
If 69 still used the bell type drum,the hub & drum are hard to separate. The lugs have to be pressed out and back in with a special tool. I think 69 used this type but not positive. I may have a used front unit of this type if it is. I've seen guys go to the later type hub with the removable drum if need be.
Old Apr 30, 2016 | 03:07 PM
Thanks a lot for your answer!
Actually, I do have the separate Hub, like the picture below:
Looking for one of this type!
Thanks! :-)
Old Apr 30, 2016 | 03:45 PM
...The part should be in good shape with foremost no play on the spindle.
I don't understand this statement as the play is adjusted out with the spindle nut. Did yours spin a bearing race inside?
Old May 1, 2016 | 03:21 PM
junior supercar's Avatar
69 does use bell drums. and I've seen both styles on 69, hub and drum one piece and the the drum separate and slides onto the hub as the pic shows.
yeahbuddy
Feb 5, 2014 11:44 AM
yeahbuddy
Brakes/Hydraulic Systems
Jan 15, 2014 02:10 PM
wesste
Wheels and Tires
Jul 22, 2013 07:10 AM
wesste
Jul 7, 2013 04:32 AM
CQGlenn
Feb 2, 2009 06:11 AM
