1968 Upper Cowl
Old Aug 13, 2012 | 09:38 AM
Badolds68's Avatar
Unhappy 1968 Upper Cowl
Hello everyone,
I am looking for a upper cowl and dashboard assembly for a 1968 Cutlass 2door hardtop. My entire windshield channel and part of the metal dash are rotted beyond repair and the donor I purchased on Ebay is'nt any better. Any leads or info would be appreciated. Thanks.
Old Aug 13, 2012 | 09:48 AM
Tom442's Avatar
Check out this old thread with some lower window channel repairs.
https://classicoldsmobile.com/forums...t-trouble.html
Old Aug 13, 2012 | 10:22 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I thought one or several sheet metal reproduction houses are stamping out the troublesome 68-72 A body cowl patches?
FYI I believe any 68-72 GM A-body has the same or very similar cowl area. The dash may be different where the pad attaches? Not 100% sure if the verts are the same but there’s more 2/4 door donors vs. verts anyway. Not a job for the meek. Its major surgery. Hotrod or Carcraft did a step by step on a 68 or 9 Chevelle vert a while back 07-08?
Check Sherman, Dynacorn, GoodMark etc… Or a good desert/ western junk yard
Old Aug 13, 2012 | 11:55 AM
bccan's Avatar
Check Chevelle parts suppliers. From previous experience you are better off replacing just that patch panel than working w/ factory panels (believe it or not). The firewall, cowl top, cowl "tub" & side panels are all layered & sandwiched & welded together. This is an extensive project dealing with all those seams whereas the patch panel would require much less work, just a little extra finish bodywork.
Old Aug 13, 2012 | 04:59 PM
Al Godon's Avatar
I have a mint one on a california car. Email me algdon23@aol.com
507OLDS
Nov 18, 2013 06:45 PM
meoff
Body work
17
Apr 18, 2013 06:24 PM
jjokrm
Feb 6, 2013 04:39 AM
dallasite21
Feb 24, 2012 01:34 PM
Alex72cutty
Feb 7, 2012 07:32 PM
