1968 Cutlass Hood Hinge
Old February 22nd, 2019, 01:04 PM
old68olds's Avatar
Looking for a driver's side hood hinge for my '68 Cutlass
old68olds is offline
Old February 22nd, 2019, 04:04 PM
Gerald Nickels's Avatar
There out there but hard to find.
Gerald Nickels is offline
Old February 23rd, 2019, 11:05 AM
geowindow6768's Avatar
If I remember correctly, 68 Delmont, Delta and 98 use the same hinges as A bodies
geowindow6768 is offline
Old February 23rd, 2019, 11:40 AM
Correct. Every 1968 Olds except the Toro use the same P/N hinges.
joe_padavano is offline
Old February 24th, 2019, 03:08 AM
68-W46's Avatar
Toro used the same hinge with a bigger spring...
68-W46 is offline
Old February 27th, 2019, 09:50 AM
Olds24's Avatar
Actually a side by side comparison shows the toro hinge has a taller front arm, that would actually open the hood further than the std 68 hinge, not sure how that would effect function on a A Body. Like you stated Toro spring almost 2x the size.
Olds24 is offline
Old March 1st, 2019, 12:00 PM
Mark in MN's Avatar
1968 88/98 had an early style hinge, and a late style hinge. Early was attached to the hood by two bolts and late by three bolts (bolts nearest the windshild also held a small u-shaped spacer between the hood and the hinge). Attachment to the fenders was the same for early or late. The late style was used in conjunction with the newer hood that was designed to fold in a collision.
Mark in MN is offline
Old March 10th, 2019, 10:47 AM
rocwal's Avatar
hings
I have a pair still on a 68 Delta , if you want let me know for price and pictures
rocwal
Dan B
rocwal is offline
Old March 13th, 2019, 07:16 AM
Olds24's Avatar
rocwal
Dan B
pm sent
Olds24 is offline
vancutlass
July 6th, 2019 04:39 PM
oldolds88
May 17th, 2019 06:29 PM
Xlhowie
June 15th, 2018 02:14 PM
Stevec
July 26th, 2016 02:21 AM
sebastien
Body work
May 17th, 2010 01:51 PM
Quick Reply: 1968 Cutlass Hood Hinge
