1968 Cutlass Hood Hinge
Old Feb 22, 2019 | 01:04 PM
old68olds's Avatar
Looking for a driver's side hood hinge for my '68 Cutlass
Old Feb 22, 2019 | 04:04 PM
Gerald Nickels's Avatar
There out there but hard to find.
Old Feb 23, 2019 | 11:05 AM
geowindow6768's Avatar
If I remember correctly, 68 Delmont, Delta and 98 use the same hinges as A bodies
Old Feb 23, 2019 | 11:40 AM
Correct. Every 1968 Olds except the Toro use the same P/N hinges.
Old Feb 24, 2019 | 03:08 AM
68-W46's Avatar
Toro used the same hinge with a bigger spring...
Old Feb 27, 2019 | 09:50 AM
Olds24's Avatar
Actually a side by side comparison shows the toro hinge has a taller front arm, that would actually open the hood further than the std 68 hinge, not sure how that would effect function on a A Body. Like you stated Toro spring almost 2x the size.
Old Mar 1, 2019 | 12:00 PM
Mark in MN's Avatar
1968 88/98 had an early style hinge, and a late style hinge. Early was attached to the hood by two bolts and late by three bolts (bolts nearest the windshild also held a small u-shaped spacer between the hood and the hinge). Attachment to the fenders was the same for early or late. The late style was used in conjunction with the newer hood that was designed to fold in a collision.
Old Mar 10, 2019 | 10:47 AM
rocwal's Avatar
hings
I have a pair still on a 68 Delta , if you want let me know for price and pictures
rocwal
Dan B
Old Mar 13, 2019 | 07:16 AM
Olds24's Avatar
rocwal
Dan B
pm sent
vancutlass
Jul 6, 2019 04:39 PM
oldolds88
May 17, 2019 06:29 PM
Xlhowie
Jun 15, 2018 02:14 PM
Stevec
Jul 26, 2016 02:21 AM
sebastien
Body work
May 17, 2010 01:51 PM
