1968 442 wiper knob
OK....I'm a moron....I thought you were looking for the switch.
I'll check tonight. I probably have a ****
Oh so you want one with original patina
that's more costly, can't be reproduced.
beware the loose or missing steel insert that keeps it tight on the shaft, says my feeble memory. I will wait for others before making the foray into the dark recesses of the garage to see if I can locate my plastic bin box of such things. It'll take weeks to get out to the cars, and I am pretty sure none of them have any *****.
As I think about it, there may not have been a **** on the car to begin with... is it held on with a set screw?
From what I gather from the Fusick catalog the 69 had a set screw. If I have one it will be for a 68. Definitely no set screw for the 68. Like Octania said there's a metal spring steel insert inside that strips out in the 68 ****. That's probably why they put a set screw in the 69's. I think the 69 **** is probably metal
oldspackrat
June 6th, 2015 09:23 AM
oldspackrat
March 12th, 2015 06:34 PM
