1968 442 master cylinder 5452310 wanted CT code
Old Aug 24, 2020 | 05:46 AM
matt506's Avatar
Looking for a core or rebuildable CT code master cylinder dared before week4 of 68 if possible thanks Matt
Old Aug 24, 2020 | 05:05 PM
rocketscientis's Avatar
Condition application
In need of a dual bale (retainer) dual bleed , oval cap unit myself...would you be willing to share with the group any details of yours that would Aid Us in the search and location of the unit you require??
Old Aug 24, 2020 | 06:09 PM
matt506's Avatar
Yes sir
it would be a dual reservoir, single bale, non bleeding type. This would be for non power drum brake setup. On the front machined half moon looking area it should be stamped CT. Should look like this one pictured.
Old Aug 25, 2020 | 08:37 AM
70Post's Avatar
Every "CT" - stamped MC I have seen has bleeders.
Old Aug 25, 2020 | 09:48 AM
matt506's Avatar
Interesting I wonder if that is the norm then on these? I suspect then mine should have the bleeders on it then? I was under the notion that only power brakes as the angle made it impossible to bleed the master cylinder due to the angle.
Old Apr 10, 2022 | 02:45 AM
Del70's Avatar
What would the casting number be for a CT with bleeders? thanks
Old Apr 10, 2022 | 09:26 AM
Del70's Avatar
I will provide myself with the info I was looking for.
https://classicoldsmobile.com/forums...linder-104132/
Old Apr 10, 2022 | 10:13 AM
70Post's Avatar
My statement above is incorrect.....talking to some Buick friends and they say some of the CT's used had no bleeders like Matt506 also mentioned above.
Old Apr 10, 2022 | 01:31 PM
RocketDevo's Avatar
The original drum masters have CT stamped and bleeders.
During the progression of this master they removed the bleeders
but continued to stamp CT on them.
Eventually they stopped stamping the code.
The casting number remained though.
Old Apr 13, 2022 | 10:25 AM
newmexguy's Avatar
Might have. PM if still looking. dave s
matt506
Brakes/Hydraulic Systems
May 25, 2020 03:23 PM
442Fred
May 21, 2019 07:38 PM
johnnyrockets
Mar 12, 2019 06:10 AM
Guy Fillinger
Dec 29, 2018 07:08 PM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
