1965 Jetstar 88: drum brake spindle wanted
Hello, i am writing form germany. I am a owner of a Oldsmobile Jetstar 88, build 1965, convertible I have to make some restaurations. I need for the front wheels the drum brake spindle. And the anchor plate where the brake cylinders are mounted on. thanx for your help. Andi
i have baught this items on ebay.com but they doesnt fit! :-(
This is a picture of my Jetstar 88
my Jetstar 88
my Jetstar 88
Note also that your driver side spindle has a hole bored in it for the speedometer cable. Be sure the replacement has this feature. The passenger side spindle will not have this.
I might have what you need from a parts car 65 Jetstar I have. Drop me a line direct at dead@mchsi.com. Regards Pat
Hey guys. Thanks for your answers.
But first i have to check if
a) the items are the same as a cutlass
or
b) ONLY 1965-66 Jetstar 88 spindles work. NOTHING else fits
What is right?
And any ideas where i get the spindles?!
The Spindle is a little bit damaged because the bearing was damaged. But however that is not the main problem. The main problem is, the bolt of the spindle is no longer straight. it is bent upwards. This has the consequence that on this side of the vehicle (the right side) the car has a knock-kneed leg (X-Leg). I hope you understand what I mean by that. As a result, the breaking effect is not sufficient. Because the brake shoes do not brake on the full shoe surface. And the car pulls to the left when braking. As a result, I don't get a TÜV (a german instution. You have to go all 2 years to the TÜV and they are looking that the car is save enough. And if not it is not allowed to drive the car)
or
What is right?
@ joe_padavano:
What is a "factory parts book" and where can I find it? What can I do with the numbers? Thanx for your great support, so I can save a lot of time!
@ 65B01Delta:
thanx for your message. I have replied it.
@ deaddds:
thanx for your pictures. I had written an email to you but got no answer. Can you send me a private message on this forum? Are the spindles okay?
@ 65B01Delta:
@ deaddds:
@ joe_padavano:
@ 65B01Delta:
@ deaddds:
@ 65B01Delta:
@ deaddds:
joe_padavano:
i dont know any part-dealer who use this book.
can you tell me which dealer use this book? And if I get the parts there.
thanx
thanx
joe_padavano:
thanx
thanx
Thanks to our member " 68 rocket action " who put these Oldsmobile parts books in PDF form and made them available for free download .
On these threads :
Thru 1975 - Oldsmobile Chassis and Body Parts Catalog - ClassicOldsmobile.com
1970 Oldsmobile Parts Illustration Manual (Chassis & Body) - ClassicOldsmobile.com
On these threads :
I appreciate that effort, but again be aware that the further you get from the model year, the greater the likelihood that the parts you're interested in were dropped from the parts network. I have a copy of the Sept 1968 book, for example. There's also a Jan 1972 version available online at gmpartswiki.com.
http://www.t.gmpartswiki.com/getpage?pageid=89287
steve-kartoffel,
Be rest assured, that you MUST follow exactly what Joe Padavano tells you --- you don't want to have a bunch of Wrong / Useless Parts...
And a lot of extra shipping charges to pay....
Our leader Joe P. ALWAYS gives 100 % perfect advice !!!
johns72olds
August 10th, 2024 07:27 PM
fritzkartoffel
October 25th, 2020 08:49 PM
StarGeneral
April 19th, 2016 07:50 PM
