Disc Brakes for a 1965 Jetstar 88
Old Jul 1, 2007 | 09:20 PM
Kaline's Avatar
I am considering buying a 1965 Oldsmobile Jetstar 88 and using it as a summer daily driver. Due to safety, I would want to update the vehicle to a dual circuit brake system and disc brakes in the front. From the research I have done (and info from Scarebird Brakes), the Jetstar 88 has an intermediate (A-body) brake system and unique front spindles, which is why I have not been able to find a bolt-on disc brake system for this car.
Questions I am throwing out to the forum:
1. Has anyone on the forum updated their Jetstar to front disc brakes? How did you do it?
2. Could I swap on front spindles from a '65/'66 Delta 88 or Chevy Impala and then put a kit made for those cars on this Jetstar? I seems logical to me, but I have not compared the parts side by side to make sure the geometry is the same between the Chevy and Olds. I'm sure the Delta parts would go on without a problem.
Any information is appreciated. Thanks!
Old Jul 3, 2007 | 12:40 PM
Kaline's Avatar
This topic is being discussed in the Brake Forum:
https://classicoldsmobile.com/forums...star-88-a.html
Old Sep 17, 2019 | 12:17 PM
No it isn't. That appears to be thread from 2007 about swapping a 455 into an '80
Cutlass.
Old Sep 17, 2019 | 03:53 PM
Originally Posted by jetstar442
the jetstar 88 uses the smaller brakes from the a body line. try using 69-72 a body (cutlass chevelle skylark monte carlo lemans) i believe these will bolt right up. and your bolt patern on front and rear wheels will remain the same. john
Sorry, but you are not correct. The 65-66 J88 uses spindles that are unique to that car. Nothing else interchanges. These spindles DO use the same wheel bearings as the A-body, but you cannot simply bolt A-body caliper brackets to them.
yopester
Mar 26, 2017 12:52 PM
65Delta88J-Scril
Brakes/Hydraulic Systems
Apr 9, 2011 10:10 AM
mauls
Feb 14, 2011 10:37 AM
Canuck
Jan 25, 2008 11:51 PM
Kaline
Jul 16, 2007 08:33 PM
