18” Fan blade for clutch fan
Old Apr 19, 2020 | 01:06 PM
oldsrock's Avatar
I am looking for the 18” six blade fan for use with a fan clutch. Application is 1970 442
Old Apr 19, 2020 | 02:03 PM
tru-blue 442's Avatar
Old School Olds
I can do a 7 blade by 17.5 if needed.
Old Apr 19, 2020 | 03:40 PM
rocketscientis's Avatar
18x6 clutchd fan..
May hav one...hav a 7x18
19 is standard 6 blade is your openin size limiting fan dia
Just sold 7x 18 to buick man...their shrouds are smaller..
Need email for pix or they are on for sale thread...either BBO water pumps or engine cooling fans I believe
Old Apr 21, 2020 | 03:18 PM
oldsrock's Avatar
Thanks for the replies. I see now that a 19" is supposed to fit both from your comments and the parts book. I actually have the 7 blade 19" and it is hitt ing the shroud. I want to figure out what's up before buying another fan.
Old Apr 21, 2020 | 04:41 PM
Old School Olds
Check your motor mounts. If they have collapsed it will cause the fan to hit the shroud.
Old Apr 25, 2020 | 12:51 AM
If it is larger diameter that would be an issue also the width of the blades on the seven is wider than the 6 and therefore brings it closer to the engine also be certain your clutch is not loose worn out but by all means don't run it like that actual 6 blade diameter is 19.3 radiator top plate and our fan shroud not being of the proper year also could contribute or the top plate being originally a three core and not properly transitioned onto a four corr will raise your fan shroud as well and remember a radiator and a hood along with the shroud is a terrible thing to waste
Old Apr 25, 2020 | 05:38 AM
ROCKETMAN269V's Avatar
I have seen this situation a number of times at my shop. Aftermarket fan shrouds sometimes are not exact reproductions. Also, check the clearance between your oil pan and the front crossmember. As mentioned above, your engine mounts could be collapsed or your front crossmember could also be collapsed. See if the long bolts that hold the engine insulators (mounts) to the frame pads will come out without hitting the crossmember. It's just a couple of things to look for. I hope this helps.
skekas33
Feb 15, 2020 11:44 AM
jpc647
Dec 16, 2016 06:21 AM
JJSCUTLASS
Jun 21, 2015 01:53 PM
76olds
Apr 25, 2014 04:13 PM
ED50469
Sep 12, 2013 08:45 PM
