68 Two Piece Rotors
Old Nov 16, 2015 | 09:49 AM
allyolds68's Avatar
68 Two Piece Rotors
I'm sure the rotors are too thin to be turned but the hubs are good. Probably not worth shipping but I will. I know I've got the other one around somewhere. $20 + shipping for both
Old Nov 16, 2015 | 10:12 PM
Yellowstatue's Avatar
If there was a source for replacement discs I would be well stocked!
Old Nov 17, 2015 | 09:00 AM
orange442's Avatar
Those were actually used up to 1970. My Dad and I have and have had several 70 model A bodies with these still on them.
Old Nov 17, 2015 | 09:52 AM
Octania's Avatar
Mucho Interesante!
What's them other threaded holes in the hub about?
Old Nov 17, 2015 | 09:58 AM
oldspackrat's Avatar
Chris,
That is where the rotor is bolted to the hub.
Old Nov 17, 2015 | 11:12 AM
Bernhard's Avatar
I have never seen a two piece rotor hub on a Olds. All the ones I have seen on Can cars are one piece? Are they common on US built cars?
Are they lighter than the one piece?
Old Nov 17, 2015 | 11:35 AM
I think the thought was to keep the hub & just replace the rotor. As orange442 stated, they stopped using this version in about '70. I've heard it was just as cheap or cheaper to cast the whole thing vs. the rotor & hub.
My '69 GTO had the 2 piece version also. I guess if you want to be 100% correct your '70 or older car should have the 2 piece set up.
Old Nov 17, 2015 | 11:44 AM
Bernhard's Avatar
All the 69 442's,cutlass's cars that I have owned and have seen have only had the one piece rotor hub. I used to spend a lot of time in the wrecking yards and have never seen a two piece hub rotor on a olds.
Could this be because the cars were built in Canada
Any idea how the two styles of rotor hub assemblies compare weight wise?
Old Nov 17, 2015 | 01:58 PM
68442's Avatar
All A bodies 68 -70 Used the two piece rotor. Up until Jan. of 70 then the cars came with one piece rotors. I have to believe 67 with disc was also a two piece.
To take it further camaros/Firebirds of the same era also followed this.
Old Nov 17, 2015 | 04:51 PM
allyolds68's Avatar
Pretty sure the Vettes used them too
Old Nov 17, 2015 | 07:08 PM
Octania's Avatar
oh, so the rotor is bolted to the INSIDE of this hub. OK
I admit to not being familiar with this setup- my cars have manual "darn near adequate" DRUM brakes.
I would imagine that the separate parts were hard to make run true enough for disk brakes. Each joint introduces the possibility for runout and out of round. What a headache. Pretty soon they decided it was best to not try to save that tiny hub.
Old Nov 17, 2015 | 09:59 PM
Originally Posted by Bernhard
All the 69 442's,cutlass's cars that I have owned and have seen have only had the one piece rotor hub. I used to spend a lot of time in the wrecking yards and have never seen a to piece hub rotor on a olds.
A '69 car would have a single piston caliper and use a two piece rotor until the excess stock was used up. My '69 Vista had this setup but my '70 Cutlass (Oshawa built) had single piston caliper and one piece rotor. The one piece rotor can't be used on a four piston caliper. Nowadays you can buy one piece rotors that fit four piston calipers.
Old Nov 18, 2015 | 09:35 PM
Bernhard's Avatar
Thanks for the reply's and sorry for the hijack.
Old Nov 19, 2015 | 04:29 AM
allyolds68's Avatar
That's fine it's keep it in top
I'll mic these this weekend and see if there's enough left to turn. It seems like .975 is the minimum required
Old Nov 19, 2015 | 06:25 AM
rr69ho's Avatar
I think you can go down to .950 Mike.
It's not like the cars are being used every day.
Chris Witt, as long as you've been messing with Olds I'm surprised you didn't know there were 2 pc. rotors up to '70. lol
Old Nov 19, 2015 | 05:55 PM
67442nut's Avatar
I thought these were only used in '67 and '68 with the 4-piston floating calipers.
Old Nov 19, 2015 | 05:58 PM
67442nut's Avatar
................I'll mic these this weekend and see if there's enough left to turn. It seems like .975 is the minimum required
Mike, The minimum allowed is usually stamped or cast somewhere on the rotor.
Old Nov 19, 2015 | 09:58 PM
Four piston calipers don't float, they are anchored solidly. The single piston calipers float.
Old Nov 21, 2015 | 04:08 AM
allyolds68's Avatar
They're at .955 now
Old Nov 21, 2015 | 10:25 AM
mrolds69's Avatar
I'm pretty sure the 2 piece deals are repro-ed now. 'Course I'm also pretty sure they are Chinesium. http://www.ebay.com/itm/like/2315416...chn=ps&lpid=82
Old Nov 21, 2015 | 10:58 AM
orange442's Avatar
Parts Place has them for $129. Just looked under 69 Camaro brake rotor.
https://www.thepartsplaceinc.com/
Old Nov 21, 2015 | 11:02 AM
mrolds69's Avatar
I'm not surprised, Heartbeat is a mostly re-seller and probably buys them from TPP. A lot of peeps don't know they are available.
Old Nov 21, 2015 | 11:11 AM
mpolds's Avatar
Two piece Rotors are 1967 - 1968 ONLY...officially
The two piece rotors were used on all GM "A" body 1967 - 1968 and Nova in 1968 that all used four - piston calipers from the factory...
The thinner hub design allowed for the space required to mount the four-piston caliper...
The brake pad was also VERY different -- and corvette N E V E R used that
set - up... their four - piston set up was unique to just corvettes (and one
other specialized vehicle)....
If the Rotor Plates are too thin -- as you advertise that they are -- you would
still be advised to save the hubs, as there is already discussion that the
plates will one day be reproduced...
Those hubs, then, become more valuable...
If anyone is need of the "D3" 4 - piston caliper BRAKE PADS -- I have plenty of them in N.O.S. ++ Asbestos ++
As indicated, this is NOT a rotor you would want being "ripped to smithereens" with this new friction material.....
Old Dec 18, 2015 | 09:19 AM
allyolds68's Avatar
Ttt
they're at .955 now
Old Dec 18, 2015 | 09:58 AM
Octania's Avatar
Oh I knew they existed. Probably have some still on the parts car. But, I have never DEALT with them in my hands, worked on them, etc.
Old Dec 18, 2015 | 10:43 PM
Bernhard's Avatar
Do you know how much one rotor and hub weighs?
Old Feb 16, 2016 | 04:56 AM
allyolds68's Avatar
TtT
willj
May 13, 2011 01:49 PM
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
bobb
Sep 16, 2010 04:36 AM
1968Cutlassfallbrook
May 26, 2010 04:26 PM
kpdandav
May 18, 2008 09:58 AM
