Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
mysterious piece part two,
Old May 11, 2011 | 04:18 PM
willj's Avatar
hoping it loads this time .what is this part , for 65 starfire,
Old May 11, 2011 | 04:38 PM
I still say it's the Johnson rod from the turbo encabulator.
Old May 11, 2011 | 05:04 PM
Oldsmaniac's Avatar
I am guessing part of a floor pan brace.
Old May 11, 2011 | 07:19 PM
TripDeuces's Avatar
Seat track or floor pan brace is my guess
Old May 11, 2011 | 07:22 PM
mfgusa's Avatar
Registered Thread Killer
Is this a quiz?... Then my guess is part of the core support. One that has been stretched with a core support stretcher.
Last edited by mfgusa; May 13, 2011 at 02:18 PM. Reason: to explain the extra length
Old May 11, 2011 | 07:55 PM
coltsneckbob's Avatar
I happen to know that it is the glutimate from the differential. If you don't put it back correctly, and soon, you are running the risk of torque integral failure on your main bearing seal. I've seen it happen and it can twist your entire transmission into a pretzel.
Old May 12, 2011 | 02:39 AM
Yellowstatue's Avatar
It sort of looks like what a Cutlass has under the rear seat, on the floor, on the passenger side to protect the speaker wire and vacuum hose for the trunk release. Lay it on the rear floor and see if the screw holes line up...
Old May 12, 2011 | 09:45 AM
Maybe we should post this in the Olds Trivia thread?
Old May 13, 2011 | 01:49 PM
GTI_Guru's Avatar
Certifiable car addict...
It looks like the cover under the trunk area that's in this pic.
http://i56.photobucket.com/albums/g1...y/IMG_2126.jpg
(shamelessly stolen from Ranzan's major build photoset)
-Jeff
allyolds68
Jul 1, 2011 03:02 PM
willj
May 12, 2011 09:01 AM
Indy_68_S
Brakes/Hydraulic Systems
Jan 2, 2011 09:23 AM
1968Cutlassfallbrook
May 26, 2010 04:26 PM
kpdandav
May 18, 2008 09:58 AM
