NOS 455 motor mounts
Old Nov 1, 2014 | 09:46 AM
jensenracing77's Avatar
This is likely the wrong place to list these. Before anyone freaks out about the price.... A set sold not long ago on ebay for $430 and I just sold a set for $425. This is my last set and are $425 shipped. These are the ONLY 455 motor mounts that are going to fit correct on 69-72 big block frame pads. You can get the others to work with a little work but these originals fit perfect.
Old Nov 1, 2014 | 03:11 PM
These are the ONLY 455 motor mounts that are going to fit correct on 68-72 big block frame pads.
Well, they will either fit 1968 or 1969-1972. They won't fit both as the 1968 cars (and the 1965-67 cars before them) used the same frame and motor mounts for both BBO and SBO. ONLY the 1969-72 cars used different mounts for BBO and SBO
Old Nov 1, 2014 | 03:37 PM
oops. I changed it. I knew that, Not sure why I said 68-72. These are 69-72.
Old Nov 1, 2014 | 08:19 PM
pogo69's Avatar
morgan
Originally Posted by joesw31
These are the only mounts that will fit correctly
I have to disagree and i am not out to kill a sale because anything i need i get nos at all possible, but the older anchor brand mounts that are USA made fit just right on the pad snug,and the height is correct no changes had to be made to the fuel line and the foam air cleaner element contacts the hood where it is suppose to
now if nos mounts were available to me i would have bought them
Old Nov 1, 2014 | 09:16 PM
johnnyjaws's Avatar
33.39 motor mounts OPG 330 455
Old Nov 2, 2014 | 03:52 AM
Same thing you can get at the parts store for $8 and don't fit correct.
Old Nov 2, 2014 | 05:24 AM
Just for educational purposes, Eric, it would be great if you could take a few pictures of these mounts lined up next to some of the "more common" mounts, which look exactly the same to my eye, and post them in Joe's Motor Mounts thread so that after your set is long gone, folks in the future can tell what they're looking for if they're in search of these.
Old Nov 2, 2014 | 05:32 AM
They look the same even side by side. I will get my all thread out and hang them all from it. With them all lined up like that the holes are close to 1/4 inch off on the block side. I think the overall problem is on both sides but it is most noticeable when you line up the frame side all equal.
Old Nov 2, 2014 | 05:36 AM
Yeah, if you could illustrate that, it might point to a landmark or a way that people could use to tell the difference, because they really do look the same to the untrained eye.
Old Nov 2, 2014 | 08:06 AM
rr69ho's Avatar
Eric, is the P/N molded into the rubber?
Old Nov 2, 2014 | 09:38 AM
They are but on this set you almost can't see them. I tried to get a picture but it will not show up. The last set I sold they were real clear. You have to be in the light just right to see it on these.
Old Nov 2, 2014 | 09:43 AM
Octania's Avatar
Nothing fits and works like real GM parts.
Old Nov 2, 2014 | 12:16 PM
RetroRanger's Avatar
72 Olds CS
If you shine a flashlight at the numbers from the side and take the image outside using the macro feature on the camera w no flash you can usually get raised or depressed areas like these to show up in pics
Old Nov 2, 2014 | 04:58 PM
nj_cutlass72's Avatar
I've had a issue w using aftermarket mounts during a swap between a 350 to a 455. Can't afford these OEMs but I wonder if there's a preferred knock off brand.
Old Nov 3, 2014 | 03:32 PM
Here are a couple crude pictures to compare aftermarket/repop to NOS. All repop or aftermarket i have found are the same.
Old Nov 3, 2014 | 03:35 PM
Here is another picture that shows the aftermarket measurement on the NOS mount.
Old Nov 3, 2014 | 04:01 PM
So the thickness of the rubber portion is different, but the metal ends are the same (at least externally)?
Good to know.
Did you try measuring the rubber at any specific point(s)?
Great shots, and thank you. Most of us will never see one of these original mounts in good condition.
Old Nov 3, 2014 | 05:04 PM
Just to look at them they look the same. When you examine them close there is little that is the same. The metal and rubber are both much differant than the originals.
Old Nov 3, 2014 | 05:29 PM
Mr Shifty Sidney's Avatar
Thanks for posting the comparison pictures.
Don W
Old Nov 3, 2014 | 06:02 PM
pogo69's Avatar
morgan
this is what i used...granted setting the engine in has to be pretty exact a 1/4 to a 1/2 inch off the mounts wont line up
Old Nov 3, 2014 | 06:05 PM
pogo69's Avatar
morgan
these
Old Mar 25, 2015 | 12:56 PM
Bumping this thread. I had two people wanting these but deleted the PMs and can't remember who they were. If you are still interested I can let them go now. $425 shipped in the USA.
joesw31
May 31, 2015 04:17 PM
Nasty455
Mar 20, 2012 04:57 PM
ctrain22
May 20, 2009 11:02 PM
sklbndt
Apr 5, 2009 04:47 PM
flatoz
Mar 15, 2009 02:03 PM
