Restored 1973 Oldsmobile 455 Hurst Olds Quadrajet Carburetor
Old Apr 11, 2025 | 09:22 PM
The Fast Forester's Avatar
Rochester Quadrajet 7043251, R4-4MC.
Original Equipment to 1972-74 (1973) Oldsmobile 455 cubic inch engine.
Cleaned and lubed carb with carb kit including:
Ethanol resistant carburetor components - new accelerator pump - needle and seat - bowl gasket - base gasket.
New power piston retainer bushing and carburetor filter installed. Original jets (70) and NOS primary (53C) metering rods. Original secondary metering rods.
New choke pull-off.
Rebuilt base plate with bronze primary throttle shaft bushings.
Float bowl plugs sealed.
Bolt on, adjust for your hot air choke, if necessary, to your needs, connect and adjust throttle linkage and fuel inlet, adjust timing if needed, idle, air mixture, and vacuum hook-ups.
I have tested this carburetor on my 350 SBC engine stand, functioning well at an operating temperature of 180-200 degrees F, and fuel pressure (4 psi).
$479.00 + shipping
yorkman
Apr 17, 2023 08:14 PM
Brians1
Feb 9, 2021 07:29 AM
Ricko442
Dec 18, 2019 05:00 PM
OldsMotion
Jan 4, 2018 10:01 PM
Macadoo
Sep 5, 2017 05:00 PM
