Selling this freshly rebuilt and tested 4 Barrel Q-Jet. I went EFI so no longer need for my build. Carb # 7041251
Asking $300.00 - shipped to your door anywhere in the Continental US, PayPal only please.
Specifics of the rebuild were completed by National Carburetor and are as follows (Taken from their website):
Idle down tube(idle jet) and idle air bleed resized for smooth idle quality with performance camshafts.
CRO(channel restriction orifice) resized for crisp off-idle and part throttle response.
Main jet and metering rods selected for clean cruise mixture and strong part throttle response and acceleration.
Proper metering rod power piston spring selected to match engine vacuum characteristics
Secondary metering rods and hanger selected and high speed air bleeds resized for maximum full throttle horsepower and torque.
Install bushings in baseplate to eliminate any potential vacuum leaks at primary throttle shaft.
Install APT (ADUSTABLE PART THROTTLE) to allow adjustment of part throttle and cruise speed (steady throttle, 1800-4000 rpm) air/fuel mixture in seconds without any disassembly, tuning can be done while engine is running!
Apply epoxy to main body casting plug to eliminate common "leak down" problem associated with Quadrajets.
New jets and metering rods.
High capacity accelerator pump featuring materials that are resistant to alcohol and other additive commonly found in today's fuel
Nitrophyl solid composite float that can't crack or sink.
Updating listing to include Quadra jet tuning kit that I forgot to put in with the original post and yes it comes with the carburetor at the current asking price
