1965- 442 400 engine
Old Nov 6, 2018 | 07:46 AM
Bob Kelso's Avatar
This is a rebuilt 1965- 400 cid engine , it has new forged pistons , ring - bearings , double row timing chain - oil pump - freeze plugs . The rods were reconned with new rod bolts , i added a Toro windage tray setup , it has been balanced with the stick shift flywheel which is included , new pilot bearing in back of crank , crank is a OEM forged steel , . This will be a true 10:1 cr engine , cam is a Crane cam that is correct for the early Olds engines- it was degreed in to specs , Block was bored and honed with a block plate . . Price is $3500 picked up at my location . Hebron Illinois 60034 . Pictures were taken before i put the oil pan on .
Old Nov 7, 2018 | 03:42 PM
kjr442's Avatar
Kjr442
Very nice.
Old Nov 7, 2018 | 05:31 PM
redoldsman's Avatar
Proud Viet Nam Veteran
This is one of the good 440 engines. If I had a 66 or 67 I would be all over this. I don't think you could buy and build it for that. GLWS.
Old Nov 7, 2018 | 07:24 PM
Fpcopo's Avatar
Bob, I hate to step on your for sale thread and hope you have good luck selling this really nice short block but are those 2 windage trays and bolts available new? I’ve looked everywhere for Toronado windage tray and can’t find anything.
Old Nov 8, 2018 | 05:17 AM
Bob Kelso's Avatar
I dont know if you can find them new but i may have some used ones , i would have to look and see . BOB
Old Nov 8, 2018 | 11:03 AM
Fpcopo's Avatar
Ok that would be good. What kind of fasteners do I use?
Old Nov 8, 2018 | 12:36 PM
Bob Kelso's Avatar
You need the Toro main cap bolts with the short stud to fasten the trays to the bolts , i use the nylock nuts for lock nuts . BOB
Old Nov 8, 2018 | 01:00 PM
Fpcopo's Avatar
Yes I will 2 studs because I just want to use the rear tray. Have you ever used the side scraper from the Toro pan? That might be something interesting to try.
Old Nov 8, 2018 | 07:48 PM
mister-twister's Avatar
Nice engine! i would be carefull with nyloc, not good with heat, and i dont want to see the plastic melt and the hardware end up in the pan. You could use a crimp nut, more of a mechanical hold for what you are fastening. Good luck.
Old Nov 9, 2018 | 05:33 AM
Bob Kelso's Avatar
Yes , you can use the crank scraper with the Toro pan . I have not had one nut come loose do to heat or other wise .
Bob Kelso
May 13, 2018 06:29 AM
Slater442
Mar 13, 2016 10:34 AM
Bob Kelso
Apr 17, 2015 04:02 PM
stonecad
Feb 11, 2014 02:02 PM
StickW31
Mar 25, 2013 12:57 PM
