Factory Oil Deflector Windage Tray
Old Mar 25, 2020 | 10:04 AM
11971four4two's Avatar
MOTORHEAD
Windage tray sold.. I DO have main cap bolts with threaded studs.
Price Reduced... I do still have 2 MORE main bolts with threaded studs with nuts $65 for pair shipped to lower 48
You are NOT going to find these Main Cap Bolt Combo at the Hardware Store
SOLD***These REAR windage trays were used on Toro , 1972 W30 , 1973 442 with 455 and manual transmission and 1974 W30 Oldsmobile. It can be used with other factory 350 and 455 oil pans.
Attaches to number 4 main cap bolts and an oil pump bolt.. Engine Main bolts with studs / threads will be included.
TORONADO ALSO HAS a FRONT "tray" MUST USE TORO Pan..
I do have 2 extra MAIN BOLTS with threads for windage tray installation $75 for that pair shipped to lower 48
Old May 4, 2021 | 03:43 PM
jmcghee's Avatar
windage tray
I will take it pm sent
Old May 4, 2021 | 04:36 PM
capstoneclub's Avatar
I gotta ask, windage tray, what was the purpose of this part?
Old May 5, 2021 | 03:39 AM
code26's Avatar
Just wondering what year toros did this come on as I have a 455 out of 74 toro
Old May 5, 2021 | 04:26 AM
MOTORHEAD
This is the aptly named "windage tray". These come in a number of designs , available aftermarket , and are even included on some factory engines.This is a factory OEM Oldsmobile one.
The idea behind a windage tray is that they provide a physical barrier between the violently moving crank with the oil it’s throwing everywhere, and the oil supply, while still allowing oil to move back into the oil supply in a smoother, calmer manner. Keep the oil from getting frothed with added air and keep it in the sump area of the oil pan
I do not know all the years they may have come on a Toronado...
Old Jan 1, 2025 | 11:55 AM
MOTORHEAD
2 Main Cap Bolts with HARDWARE available $65 shipped to lower 48
Old Nov 7, 2025 | 09:26 AM
MOTORHEAD
Pair of main cap bolts WITH threaded stud end to hold windage tray $65 shipped to lower 48
Gary M
Dec 31, 2017 04:39 AM
David DeCan
Dec 15, 2016 10:30 AM
hilbily
Aug 11, 2014 08:37 PM
70 holiday coupe
May 31, 2011 08:02 PM
hamm36
Nov 1, 2008 08:02 PM
